Deciding between old GE and KitchenAid Hobart
jkm
Member
Oct 29, 2021
8
Houston
We have small house built in 1950 that we are setting up as time capsule, so to speak. We have secured a '57 Frigidaire range and '54 GE Fridge. Both were inspected and refurbed by a local appliance specialists specializing in the respective appliances.
When it came to getting a modern dishwasher though the problem with getting a white dishwasher these days is that only the lower end models are have white options because stainless is all the rage. And everything is on backorder because we're waiting on chips from China to get offloaded from the boats. So then we were looked into getting a new panel ready dishwasher and one of the Northstar or overly pricy Big Chill retro panels. The panels range from $500 to $700 and they're still just going on a dishwasher designed to last only 7 to 10 years.
But then we came across these two older automatic washer models.
A GE Automatic and a KitchenAid Hobart.
Both are for sale at $100 or less and they supposedly both work.
I don't have photos of the labels yet so I haven't been able to specifically identify the models.
I've been reading up here to look out for pros and cons, and I'd appreciate feedback. I'm tempted to get both if I can find a place to store one.
Thoughts? Opinions?
The GE would be more period correct with the rest of your kitchen appliances but will suffer in the performance, durability, and reliability areas compared to the the Kitchenaid. The GE will be harder to find parts for. Just be aware that you will be the repairmen/person if either machine requires attention. Nobody is going to bother chasing down obsolete parts and most are not going to bother trying to repair them, even if they have the knowledge, which most don't.
[this post was last edited: 10/29/2021-23:54]
TBH either would be perfectly correct as a replacement for, setting the stage, a GE drawer dishwasher installed when the house was new, then swapped out for another GE in 1969, or hung onto for a littttle longer until 1979 when milady just COULDNT see herself with a plastic (Permatuf) dishwasher and wanted the best at the time (but saw no value at not having a dial to turn...KA
Repair and years
Actually, if we need repair the house is in Oklahoma City which happens to be home to Tyson's Appliance Restoration. They specialize in restoration and repair of older appliances. That said he mostly gets stoves and heaters and did say it was harder to get parts for dishwashers. But they are the one that checked out my 57 oven.
So the GE is from around 69 and the Kitchaid is probably from 79?
Do you rinse dishes before loading them in the machine or do you just scrape off the food soil? Do you load pots, pans and mixing bowls in the lower rack or do you just load plates in the lower rack? If you rinse and only load plates in the lower rack you can get by with the GE. If you ask the machine to actually wash the dishes and load water blocking items in the lower rack, the KitchenAid is the machine for you. Do you see that wash arm under the upper rack? That allows you to fill the lower rack with water-blocking items and still get water to the upper rack for your cups, glasses, small bowls, plastic items etc. You should look into acquiring a rinse agent dispenser for the KitchenAid if that is the machine you buy.
G E DISHWASHER age...
Very likely 1965 , just before they changed the design...it might be a year earlier, cause there's no plastic flatware shield at the base of the inner door...I'd snap it up just cause it's a historical piece in such good shape !
Thanks
Thanks to everyone for some help in identifying the models and age. And thanks to Tom for good tips on how the units can handle washing. I'm actually going to try to get both but the person listing the Kitchenaid is not responding. So we may just be happy to get the GE and thanks to Tom's tips we'll know how to work with it.
Having had GE and KA. some thoughts
Either will be better than a new machine.
Both will need occasional repairs, start looking for donor machines.
Both will have rust, no matter what. Laundress gave us some good notes on fixing that a while back.
The GE only needs to have large items, olive pits, bones, etc. scraped off. No pre-rinsing needed. A modern detergent and rinse aid will work fine. Expect the machine to break fine china and melt plastic in the bottom rack.
Loading is intuitive.
The KA prefers to be fed dishes which are pre-rinsed, not just scraped.
Modern detergents may foam a bit too much, you'll have to experiment - the KA uses a much better wash arm then the new dishwashers. You can get better results with 1/3 as much detergent.
Loading is as non-intuitive as anything can be. You'll learn. Eventually.
KA fans are a bit like apple fans, GE fans are a bit more Windows people.
We use both regularly, but the GEs are my personal favorite and my partner doesn't mind how fussy loading the KAs is.
Again, either is a better choice than the plasti-elasti junk on offer today.
Got the GE
We got the GE. The Kitchen Aid was pulled off the market for some reason. I also managed to pick up a 1975 Tappan dishwasher that was still fully functional as well. It's the kind with four color panels: white, harvest gold, avocado, etc.
So the GE will likely melt plastic dishes if they're on the bottom rack? That means we my 1950s atomic Melmac dishware will be in danger if the dishwasher is not loaded correctly, right?
Yes, I wouldn't subject the melmac to a heated dry cycle. I'd love to see pics of the Tappan. Possibly could be the last of a real Tappan dishwasher.
Melmac doesn't belong in any dishwaher
I don't know why, you'd thing the melamine resin would be stable, but it's not.
The reason you can't put thermoplastics in the bottom rack of the GE is because the element heats the water pretty much whenever the motor is on and the drain solenoid is off.
They were down rated from 900Watts to 450-500Watts at some point, but even the lower wattage elements are a big reason for the outstanding performance of the Potscrubbers.
You just can't clean with tepid water.
I'd not sweat it, but no melamine resins in the Potscrubber.
(I wonder if non-chlorine detergents have changed that equation, today? Next time I have a piece of Melmac I don't care about, I'll throw it in for several washes and post the results.)
A Tappan! Cool! Pics, please!
Checking out the GE
So I found out that Tyson's Appliance only works on vintage stoves and ovens. There was a miscommunication when I talked to them about dishwashers.
So I may end up doing the maintenance myself. I was looking the GE over to see if there was any preventative items I might consider fixing now instead of letting them become a bigger problem later.
Here's the label info:
Model:
SD400B1
Serial:
ZA5-07094
Potential Item One
So this If I understand correctly this GE has a "Plastisol" liner. It looks like some kind of spray on liner on top of a metal tub. It also looks like I have a rust bubble under the plastisol or a place where it's separating from the tub. Please see the photo.
I imagine this happens. Is Plastisol something I could re-spray if I tool this part of the tub down to metal and repaired the metal?
Potential Item Two
I'm guessing the rinse glo knob is for Jet Dry or some rinse aid. It does not turn. I'm guessing I need to take the door part and clean out this unit?
Potential Item Three
The top washing arm does not hang perpendicular. It is larger on one end which could explain that. Is that normal or is something worn out?
Other questions:
1. How can I tell if this requires a 20 amp outlet?
2. I found the owners manual: https://www.automatice.org/cgi-bin/index.cgi?showdoc~1415~General Electric~DW and I don't mind purchasing a service manual but I'd rather like to know if this is just a parts dishwasher or actually serviceable.
3. Has anyone found an easy garden hose to input line adapter that would allow me to hook this up to my hot water heater drain faucet and simply test the unit's operation outside?
In the late 60s & early 70s, we saw lots of Melamine plates with charred edges being brought into Rich's department store because we would take back anything, but to a customer, they had GE dishwashers with that small heating element under the lower rack and it burned up Melamine. We would not exchange the burned dishes, but we would sell them Corelle dishes. Serrated knives on stainless steel flatware carved up the plates and the arrangement of the heating elements on GE dishwashers which were put in so many homes by builders finished them off. The old bow tie impeller machines did not harm the plates because they were not racked right over the heating element.
They don't hold up to a dishwasher heating element.
They are not to be used for microwaving.
Acidic foods can cause the chemicals in the plates to leach into the food.
My guess is the stain easily and the are easily scratched when cutting food on them.
What?
I think I'll stick with my 20-40 year old Corel ware.
Best Sightly Vintage DW
First don't brother with this GE DW trying to use this as a daily driver is like trying to use a 1971 Vega as your daily driver.
These GE DWs were fairly reliable for 5-10 years when new but were never intended to last a long time and worst of all they only did a mediocre job at actually washing dishes when new.
Where the tank is rusted there is no metal left under the rust to redcoat, yes you can start building up epoxy and use some of the good sealants to fix this problem but you will just deal with it in other difficult spots elsewhere.
If you want vintage get a Kitchenaid, they were light years better to begin with and parts are still all over the place, we have a whole wall of KA parts for the KD15 KAs and on we have almost nothing for a GE like yours.
A few answers
Home depot and Menards both sell dishwasher hookup kits with 'universal' adapters. UPC Code #820633958697
That might meet your needs.
The top sprayer is always a bit out of perpendicular, if it spins freely, it's ok.
Plastisol...not one of GE's best ideas. Laundress has posted extensively on how to fix it and, yes, that's a rust bubble.
I like GE dishwashers. I like KA.
Some KitchenAid fans tend to be a bit...well, let's just say they never quite recovered from Consumer's Union rating the GE higher in cleaning really dirty dishes.
Never dealt with a recalcitrant Rinse-Glo cover, perhaps hot water to loosen?
I would go with a KA, even one from that era and I don't even like their one level wash arm that they used up into the 70s.
However, as others have pointed out GEs back then had a plethora of problems. It's ultimately going to be a bunch of problems.
Unless you just want it for the looks, which is understandable. Still, I think I would go with a KA over GE.
Good Luck
