Re:17
“Having worked in this field a long time we see mistakes all the time that manufacturers make many people on this site, including you, Eddie, know more than many manufacturers.”
Well John, I just looked at the owners manual for your beloved Speed Queen TL’s and it says explicitly to place the detergent in the BOTTOM of the tub, then add the clothes, just like the manuals of ALL the other TL’s. So I guess you know more than Speed Queen.
Back in the good old days when TL’s didn’t have flow restrictors that limit the incoming flow of fill water it certainly made sense to add the detergent on TOP of the laundry after putting in into the tub. The fast fill would quickly devolve the detergent so it could disperse evenly with the laundry.
Now, washing machines fill slowly and sporadically, often stopping to adjust the rate of hot versus cold water to satisfy the auto temp control. Adding the detergent on top of the laundry can result in a paste of powdered detergent sitting on the clothes during the fill process before agitation begins which could cause stains on darker clothing.
Adding the detergent at the bottom of the tub insures that the water filling the tub will drain down to the bottom of the tub, into the outer tub and mix with the detergent insuring that it is evenly mixed with the water by the time agitation begins.
You do it your way and I’ll follow the instructions of the manufactures.
Eddie
Eddie
