I frequently read about how good or bad some detergents seem to rinse out.
Personally I always use the extra rinse and high water level option because I think most washers are way too stingy with water and also to be on the safe side in case of overdosing.
However I just don`t believe that seeing no suds or cloudiness in the last rinse water equals less detergent residue. (Assuming the same type of fabric, same cycle comparing the same amounts of different detergents)
If sudslocks are a problem, I can see the point for very low sudsing easy rinsing detergents, otherwise I don`t mind some bubbles in the last rinse. Am I wrong ?
