Diffences between Maytag DE and DG dryers
moparman
Active member
May 29, 2021
31
Patton
So, kind of stupid question, what are the actual differences between gas and electric Maytag dryers? Is it just the burner and heating element or are the harnesses and timers different? And how much doesn't interchange between the two? Can you change a DE to a DG and vice versa? I'm just curious and thought it would be an interesting topic to discuss and learn from.
The Maytag DE/Electric Halo Of Heat dryers have the heating element that goes in a circle around the entire front of the dryer hence the name Halo Of Heat. The Maytag DG/Gas Halo Of Heat dryers have a access panel on the bottom right hand corner of the cabinet to have access to the pilot light and gas valve.
You can convert a Maytag Gas Halo Of Heat dryer to electric but it’s pretty much impossible to convert a Maytag Electric Halo Of Heat dryer to gas since you need to access the pilot or gas valve and the electric Halo Of Heat dryers don’t have the small access panel in the front to access the pilot or gas valve.
Here's what I recall from owning both types of HOH dryers:
The HOH dryers have entirely different heating system designs, with the gas models producing a flame at the bottom of the machine that sends heat out and around the front of the drum.  Electric models have a coil that encircles the entire front of the drum.   I imagine converting from one source of heat to another would pose quite a number of issues including voltage, but nothing is impossible.
I have seen later Maytag electric dryers that concentrate the coils into a similar housing to that used on gas models.  Those designs might lend themselves better to attempts at conversion.  Only the dismantlers among us know for sure.
But what about the stream of heat? I know those carried through to present day in the lower models, like my mom's MDE9306AYW
