Dishwashers losing popularity in US Homes???
How do I get my family to understand there's no need to pre-wash or pre-rinse your dishes?
Honestly, I have no idea. Explain that unlike previous machines, your new machine can indeed handle your dishes dirty. That they will get clean and the soil will be flushed away while suing less water and energy.
Of course, its no guarantee.
Everyone who knows marketing, human behavior, psychology, ect knows a first impression is everything.
I mainly use, and I refuse to run water over the dishes before going in. First of all, the detergent is caustic. Second, there are enzymes, and third, the racks will be ruined and dishes/glasses will be etched if I rinse dishes.
Correct, all correct.
Unfortunately, most dishwashers in existence aren't like yours Jerome. Be happy you have a machine that can actually be called an automatic dishwasher.
It is interesting to see the variability in comments about one's using a dishwasher. There is no right or wrong, per se, just what you feel is right for you. Personally, we live around our dishwasher. As the day progresses, we just pop in the dishes from meals, snacks, etc. At the end of the day, or sometimes the next day, just pop in a Cascade Complete pod, and then go about normal business. No muss, no fuss just clean dishes.
As mentioned in a previous post, when we purchased this house, the inspector found the builder installed dishwasher, a Whirlpool, leaked. The builder offered an allowance and pulled out the new Whirlpool. I stuck in my GE Tower Wash dishwasher. I plan to occasionally alter it with my Maytag Reverse rack. My two favorite machines. My tower wash gives impeccable results in about 90 minutes. Even if the Whirlpool hadn't been factory defective, I would have pulled it and sold it. I won't trade quiet for performance or speed or quality, so I will likely will never own a new dishwasher as I would likely have to compromise on at least one of those three parameters. I was astounded at the build of the new Whirlpool, unbelievably flimsy plastic door and cheap racks.
There are many reasons why people don't use their dishwashers. When questioned, I often find at least one of the three unpardonable sins have been committed, 1.) water ENTERING the dishwasher is less than 120 degrees. F (too many people unwittingly set their hot water heater to 120 degrees, not realizing there can be substantial heat loss in household plumbing.) 2.) People have hard water (over about 10 grains per gallon hardness) Calcium binds with detergent at the molecular level and reduces the detergents' ability to remove food wastes and hold them in suspension, not to mention calcite deposits in the form of spots. 3.) Non-quality detergent. Dishwashers ability to clean is directly proportional to detergent quality.
Hot water, soft water, and quality detergent makes for sanitary and sparkling (literally) dishes and pots and pans....
A dishwasher, of any brand, can't do it's job well unless you give it the above three things. Give your dishwasher what it needs and it will be your best friend.
BTW--It's almost ten p.m.,...only two hours until Santa Comes!!
Wishing all my friends at Automatic Washer.org, a Blessed and Merry Christmas!!
Same! I bought a dishwasher to wash dishes. I'm so over my Kenmore by Whirlpool. It didn't clean as well as the LG.
Whirlpool needs to bring these back. Why do you think kids don't like to pre-wash or pre-rinse, nor do they want to deep down? I don't! I don't want to. That's the point of having a dishwasher. You should do it anyway. It does it for you.
There is no product, design or patent that Whirlpool needs to bring back into production than the Whirlpool Power Clean Filter Module. If everyone in the world was like me that would have happened 15 years ago already. Actually production would never have seized. But sadly society has collectively doesn't know what was lost. It is a very dark, and sad world right now.
My old Kitchenaid KDC-19 has upper & lower spray arms that have forceful sprays.
And it's not really annoying in operation.
The wash takes 1 hour, then the forced air dry takes 1 hour.... not an issue.
But then again, that's when they made a damn good dishwasher.
Damn my typos! I once owned a Hobart made KitchenAid. It performed flawlessly and made much less noise than I would have, if I had to do dishes by hand.
People who put dishes directly into the dishwasher don't like these new tall tubs. The Whirlpool my mom had wouldn't clean dishes, especially the glasses in the upper rack. She always used pots/pans + soak/scour. This is so stupid!
I always leave the door ajar when there’s dirty stuff in there. The dirt dries up quickly so it doesn’t stink, even after 5 days. But that’s only an option when you don’t have creepy crawlers around that want to get into the dishwasher.
I have the edge of my dishwasher sprayed with raid when necessary so my dishes don't have ants crawling all over them, this way they die before they can get to them.
I have the edge of my dishwasehr sprayed with raid when necessary so my dishes don't have ants crawling all over them, this way they die before they can get to them.
I must be lucky.
I've never had ants in the house.
On very rare occasion, maybe a stray waterbug that wanders in.
But I do get a few cobwebs from spiders.
The vacuum takes care of those webs.
Very old fart here. I think (scary, huh?) that in order to cut down the noise, dishwasher manufacturers have reduced the force of the spray, (which may also be why the motors or so tiny these days) so the machine really does need more time to do its job. It may also be why when draining, dishwashers no longer masticate soft food particles, so there's a filter to clean periodically. Just my observations and opinions, I could be wrong.
Yes, with no food grinder, machine is more quiet or at least that is my theory on meeting low noise levels, but there is a GE model with grinder that is low noise. The filter replace the grinder.
It's so funny how my experience being 3 weeks without a dishwasher back in 2014 while waiting for my Maytag was HORRIBLE... I had relied on a dishwasher for so long and gotten so used to my system that it was almost traumatizing. It's just multiple times a day something might end up in the sink... Open dishwasher, put it in. Later, do the same thing, slowly the dishwasher collects and holds the dirty dishes OUT of site until it's full and time to run it (for me it's every 2 to 3 days. I'd say average 3 times per week. Run it, unload, repeat. Doing them by hand it drove me crazy because there would be dishes in the sink. I'd have to stop, wash a glass, a few knives, a spoon, a bowl... then later, a plate and another glass... It's not like you have this one massive load of dishes to do at one time (at least here) It was a total inconvenience and I hated it. I will never understand how anyone can NOT want or use a dishwasher.
I just can't fathom why someone would not want to use a dishwasher. To me, washing dishes is a CHORE. It is drudgery. I have friends younger than me that hand wash with families of 4+, throw holiday parties and hand wash for all that mess. My mother never wanted a dishwasher. My stepfather did not want one either, but I've only seen him wash dishes once in my life. I lost track over the years how many huge parties and family dinners at my mom's house with stacks of dishes, glasses and pots on every surface. I always tried to help, but she claims that she didn't mind doing the dishes. Unfortunately, she is not the greatest dish cleaner. I had to rinse out a glass at her house on Xmas that I thought was used from the cabinet. The others looked similar. I love to cook. My dishwasher cuts down on the chaos in my kitchen. My dishes are sanitized and sparkly and have the same level of cleanliness. My mother and I have a pact that if I ever have to move back home to help them if they are sick or injured, a dishwasher will be there before my luggage is.
Christmas meal two days ago at the mother's house w/the two sisters and SIL. Paper plates and drinkware. Standard metal/stainless cutlery. They handwashed everything, including all the bakeware/prepware. New dishwasher installed Nov 2024 during the house/kitchen refresh before sister/SIL moved in w/mom has been run twice or thrice at most. Sister ran self-clean on the wall oven, interestingly, presumably the first time.
I refuse ot wash anything by hand. Dishwasher always used. My monthly sewar rate is determined by water consumption during the months of January to March and the basic rate is determined by a maximum of 2,000 gallons every billing cycle. I've always had the minimum sewar charge all 40+ years I've lived in my house (well except for the time I had the water hog Filter Flow. Now that there are two living here, I'll see how it goes. Ted prefers washing everything up 2 or 3 times/day I may just let him continue his way and see what happens with increassed billing.
Oh lord!
God forbid that an appliance would fail in some households!
Being so extremely dependent on it would cause pure chaos!
The "drudgery" would be too much to handle!
Think of all the terrible issues that would result!
A sinkful of dishes, making hands worn out, wrinkled up from detergent!
Or a washing machine breakdown... Yikes!
And having to beat garments by hand on a rock by the stream!
Utter torture!
All that labor involved in chores!.... no energy left to tap on "apps" or service the hubby's needs.
Simply dreadful!
Well Phil, I have some physical challenges snice birth and as I age, I've adapted to allow myself to continue to be productive and independent. I let the dishwasher wash all dishware and cookware. My dryer is the Iron in this house and has been since me graduating from college in 1977 and working until retirment in 2021.
