Everybody has, of course
pointed out the obvious - CO is nothing to mess with. In fact, when that dryer is going full blast and exhausting to the outside, take a look at whether your gas furnace and water heater are down drafting back into the house - if they are, then you have a problem.
The advice to up the spin speed (which you can do cheaply with a stand alone centrifuge) is undoubtedly the best single step towards saving energy. I'm not going to endorse the spinner at the link, I've never used it. My German spinner does, however, cut the drying time by more than half - and it spins at 2800rpm (and I've used it for over 20 years with no damaged clothes, an old debate we've had here for centuries). A few other things which will help, too:
Try to dry on days when the ventilation is useful - that dryer is pulling in quite a bit of basement air, make use of it. If a window would be open anyway, then it's not such a painful loss.
Make sure you dry at least two loads, one behind the other. There is quite a bit of mass to heat up in a dryer and drying two loads or more back to back saves some energy.
What Laundress said about all that icky lint also applies to the innards of the dryer, the vent hose (best if it's a straight, smooth pipe with minimal joints and approved for gas dryers) and the exhaust vent cover. Especially if you use fabric softeners or dryer sheets, it is sheer unbelievable how much lint and dust builds up everywhere. Best to unplug the dryer first, though and watch for very very sharp edges. I had a Sears gas dryer peel quite a bit off my thumb many years ago when I only brushed against an inner edge.
What about hanging things up to dry until dry or nearly so outside then giving them a last, short heated tumble to make them softer and finish drying them?
If you have the opportunity to reuse the last rinse water as wash water and don't use a fabric softener, a trick from the bad old days of low spin speed washer-dryer combos was to use hot water for the last rinse. It cuts down on the drying time quite a bit - but only really saves money with a gas dryer if you can then reuse that clean, formerly hot water for a warm water wash load.
Hope that all helps.
