Dryer Sheets
Does anyone else use dryer sheets? I thought I would give these a try as I love the scent. I also don't like the idea of liquid softner in the washing machine so I use it on occasion.
I'll stick with Downey, diluted with warm water.
Today's load of T shirts and sweatshirts came out nice, as usual.
I don't like those dryer sheets, never did, I don't care what they smell like.
Just my two cents....
I've used sheets a few times, probably no more than three boxes over the past forty years. Sheets presumably require contact with fabric, I don't think they distribute evenly throughout the load vs. liquid products.
I don't use softener on every load.
Thank you for the input. I'll keep this in mind and see how this load turns out. For me softner is more often about the smell than the softness. No smell is great, but sometimes a warm towel with a touch of lavender or spring flowers perks me up.
I usually use them. Some people are heavy handed with them (using 3 per load), but usually will only put 1 or 2 in at most.
Not one of those scent fanatics, but sometimes just want things to smell clean as assurance for the effort put in.
Ok, so after doing two loads with these sheets I can say I like them. There is softness to the towels and jeans, but more importantly a notice a nice light scent which I particular enjoy. I will keep using these sheets for select loads, they are nice. And they make the dryer smell nice too.
We only use scent Free dryer sheets. Never liquid softener. My daughter in law also hates the residue buildup from liquids in the dispenser. I did use liquid in my old Maytag because the dispenser was in the top of the agitator and easily rinsed after use.
I've watched a video of a tumble dryer being torn down and repaired on youtube, where the previous owner had used dryer sheets, the stuff from the sheets had run down inside the case and had also coated the conductivity sensing wires so autodry didn't work properly until they were cleaned up.
Personally, I'd rather my laundry wasn't scented. I do use fabric conditioner, to deal with static and improve softness, but choose a lesser scented one. That said I use to find the scent left by the detergent I currently use due to it being regularly discounted, rather overpowering, but having lost most of my sense of smell since covid, I no longer notice it.
Yes, detergent and softener residue buildup can affect dryer efficiency and make lint cling to parts and the plenums. Scented are worse though. American tumble dryers are very large and it takes years for any resude to affect it. Our previous dryer was 15 years old and the auto dry was still working great. It had only had been vacuumed out about every 6 months in the lint and exhaust plenums.
I use them almost every time except for like towels or quilts. I rotate between Bounce and Kirkland. Then I'd take the old sheet and use it to remove the lint from the screen.
I stopped using any kind of fabric softener almost a year ago. The liquid softener leaves a greasy build up on the washer which I despise and the dryer sheets really don’t do much in adding a fragrance to the laundry, the only thing they are really good for is to use to take the lint off the lint screen.
Instead I use 6 dryer balls. They fluff up the laundry, separating it as it tumbles and facilitates faster drying times. I do like the scent that liquid softener imparts, but I’ve found that using Ariel Powdered detergent which has a pleasant scent is sufficient to impart a pleasant fragrance to the finished laundry.
Makes doing the laundry much simpler and less expensive too.
Eddie
My nifty way of cleaning the lint off the dryer's lint screen is to hold it above a small wastebasket next to the dryer, and use a soft bristle 2" paintbrush to wisk the lint right off the screen.
Works like a gem and takes a mere couple of seconds.
