Dual Action Speed Queen
Can we get details on this conversion-this would be good to know!What sort of mod made to the washer and agitator to accomplish this?Its a GREAT Mod!So if I spot an older Maytag at the swap shop-I can "Primp my Maytag" with the Roto Swirl-usually the swap shops have these and other agitators lurking in their junk piles.
That one really pushes the envelope: A Kenmore agitator grafted onto a Maytag agitator topped off with a Whirlpool cap.  It looks so wrong in that 'Tag...but wow, witness the classic Kenmore no-holds-barred rollover.
Thanks for sharing these mad, mad experiments with us, Martin, DanManTN, Bob, and Jeff.
yeah, the RotoSwirl seems to work best in a Maytag, plus tack on the 50hz upgrade....
I tried a GE straight vane once, with a regular pulley, nothing spectacular, but was meaning to try out a GE ramped, thinking that would give better results, and by the look of the Kenmore version, it works really well....
heat welding the two polypropylene skirts together
Tom, thermoforming plastics generally weld fairly well and it's a pretty simple thing to do. Polypropylene is one of the easier plastics to weld too. We have a plastic welding setup here at the machine shop. Years ago we made a number of tanks and fixtures all from Polypro for a local semiconductor manufacturer. Years ago I worked with a local motorcycle shop and we welded broken fairings, most of this was ABS (easy) or Nylon (not so easy).
A plastic welder is basically a concentrated heat gun that looks like a large pencil-style soldering iron. They will use either compressed air or nitrogen or other inert gas which the element heats to as much as 900 deg F. Often times there is a tip that has a plate that helps press the filler material into the weld area.
Joint design is very important for plastic welding. The filler material goes soft (plastic state) but never really flows like when welding metals. It is important to get a close fitting joint. Provided two agitators could be fit together decently they could be welded easily and securely. Dr. Frankenstein the lab is calling!
