whirlcool
Actually it's the idler wheel that will need to be changed to a 60Hz model if you are converting from a 50Hz model. Most all Dual turntables are voltage switchable. Some models have a voltage switch while other models just have you swap a wire or two on the start switch. The method to be used for any one Dual turntable is detailed in that model's Service Manual, of which are readily available on the internet.
And if it's a belt drive turntable that is to be voltage converted, a new drive pulley for 60hz will be needed. These are still available from some suppliers.
