applianceguy47
- Joined
- Mar 19, 2012
- Messages
- 590
I currently have a Whirlpool Duet WFW8300S. I've also had other Whirlpool Duets.
Behind the front lower panel is the pump and before the pump is a lint/large item trap, that protects the motor. If you wash items that give off lots of lint, this trap can easily become overloaded and block the flow of water and create the need to access and clean out the filter.
This means removing the somewhat difficult to remove bottom panel. Most front loaders have an access panel but there are a few models that don't.
My solution was simple enough.
Here is what a typical Duet looks like. Notice the bottom panel is blank, with no removable panels or protrusions.
