stevet
We have a WP WFW9150WW00 Duet which is just over 2 years old and it seems to have a problem when it comes to filling up to rinse after the main wash. That is to say, it will not fill with the normal amount of pressure into the dispensewr so the bleach is not dispensed nor is the fabric softener if used.The rinses are nearly non existent as far as filling with water.
The initial wash fill whether hot, warm or cold all work fine but when it goes to fill in the first rinse which dispenser the bleach, the water will trickle into the machine and there is never enough water to rinse the clothes. So then with each spin cycle, sudsy water is extracted and is flung against the door glass and seems to accumulate in the boot even though the boot drain holes are clean.
This happened about 8 months ago and I changed the fill hose which seemed to fix it but then it reverted to its old habit at which time I changed the fill valve which also fixed it until now.
It seems that it will return to normal pressure if we wait enough time to restart the machine like 10-15 minutes, but then the slow to no fill occurs again during the rinses.
I thought maybe somthing was clogging the drain trap causing the sudsy water backup during the spins or water was staying in there and causing the pressure switch to think there was water in the tub. That changed nothing after cleaning it out as well. We did a wash with warm water and extra rinse and nothing happened after the initial fill again.
So, would anyone want to venture a guess or a solution? Is it a valve problem, a control board problem, a pressure switch problem?
I am going to take the hose off the switch when I get home today and make sure it is not blocked in any way so I will report back later on that.
Hopefully I can get this resolved.
The lady of the house has already commented to the effect of "Yeah, talk me into another front loader the next time we look for a machine!"
Thanks
Steve
Thanks
Steve
