E.Coli on laundry (not for the highly-squeamish!)
Designgeek
Dec 12, 2004
865
This topic will be dealing with the question of bacterial persistance on laundry. Don't read this if you're highly-squeamish about poop and suchlike.
In another topic, Launderess said:
Post# 53375-1/13/2005-20:53 ||| Launderess (United States)
Tide With Bleach
Read the fine print on the box and you will see that particular version of Tide is effective against a small list of bacteria. The most commonly found bacteria found on laundry, E Coli is NOT listed, and it is all over everyone's wash.
Normal laundering methods; hot water, mechanical action, change of water temsp (hot to cold), and chemicals contained within modern laundry detergents do a pretty good job of killing bacteria. If you want to take things furhter, there is always chlorine bleach (still the most effective and wide spectrum disenfectant available widely), or very hot wash temps for an extended period of time.
Launderess
Okay, first issue: Whence come all the e.coli in the wash...?
If I'm not mistaken, e.coli is fecal coliform bacteria.
That suggests it comes from underwear. Even someone who's fastidious about wiping their bottom when they poop could have e.coli present on the skin in the region, which can't be removed by the toilet paper. So then, the e.coli would transfer to their underwear invisibly. Is that approximately right? You'd change your underwear daily, it would never have a visible trace of poop or anything, but it would still have picked up the e.coli from your bottom. And then it would sit in the laundry basket for a few days before making the fateful trip to the washer.
This has implications for dirty laundry storage: to not use traditional baskets with their open mesh sides (bacteria could escape onto the bedroom floor), but instead use baskets that have solid sides and bottoms, without perforations. And also, to never use the same basket to carry the clean clothes back from the laundry room, as was used to carry the dirty clothes to the laundry room (I'll have to admit I've been guilty as h*ll of this one.)
To complicate matters slightly, if the e.coli are transferring invisibly from one's bottom to one's underwear, could they also transfer through the cloth of the underwear, to the cloth of the outer garment worn over the underwear?
So, even if you have two separate laundry baskets, one for whites, the other for colors, your dark pants (e.g. blue jeans) have already picked up e.coli and it's now in both laundry baskets, right? (Oh lovely!)
This gets us to the key question: what procedures can be used to kill the e.coli or reduce it to a safe level without growing resistant strains?
For example, wash all whites in hot water. Okay, but it takes 160 degrees Fahrenheit for at least 5 minutes, to kill 100% of bacteria in food, so it would seem to be the same requirement for laundry. However, the plastic tubs & components of many modern washers aren't rated to that temperature. And household water supplies aren't set that high.
So now you add bleach to the whites. Okay, how much bleach? What I'm looking for here is a ratio of bleach to clothing, or bleach to water in the washtub, so the quantity can be adjusted to various load sizes and washer sizes. Assume liquid bleach e.g. Clorox or its generic equivalents of the same strength.
This has implications for users of twin-tubs and suds-return machines: never recycle water from a load of underwear into a load of outer garments.
Also, for anyone, for all washers generally, wash outer garments first, then wash the underwear/whites load, handle colored socks separately, and after the last load, wipe down the interior surfaces of the washer with a dilute bleach/water solution and leave the lid open to allow fresh air circulation. Is that right, or have I missed something?
Another implication, is that this might be a serious reason to buy one of those "micro-washers" such as the Cyclone or its Sears equivalent, just for the purpose of handling socks as a segregated load, to keep those pesky foot-bugs from transferring to other garments.
(And I also have to admit I've always done mixed loads in cold water, yow!)
Then comes the drying cycle. To what extent do modern dryers get clothes up to 160 degrees and above? Seems to me that would be the point at which all the water has been removed from the garments i.e. when they are bone-dry, and then the drying is continued in order to raise the temperature to the appropriate level. At this point however, it wouldn't seem terribly urgent to separate the garments by color aside from fabric care issues, if all of it is going to get nuked at 160 degrees.
Alternately, are all of the possible segregated-washing procedures unnecessary as long as all the clothing is nuked at 160 degrees in the dryer? (I always do this step and have thought it was sufficient by itself.)
All of this may sound like so much anti-germ paranoia, but the fact remains that we are presently seeing the emergence of many new and resistant bugs. Antibiotics are starting to fail to a degree that has public health physicians pulling the proverbial fire alarm. Therefore, once again, sanitation becomes the first line of defense against potentially serious illnesses.
We're all aware of the need to wash hands after using the bathroom, before preparing or eating food, and upon coming home from public places such as work, school, or shopping. However, most people (in America at least) probably aren't fully aware of the public health implications of the way they do their laundry. I get the impression that this needs to change.
Hmm. Scientifically speaking, this makes a certain amount of sense: e. coli on underwear-->wash water-->other clothes.
On the other hand, I've lived through 44 years of having family bacteria spread through the laundry and show no ill effects. No, no--my insanity comes from OTHER sources!
As for laundramats, well, I'd rather not think about that too hard.
I'm as squeamish as the next guy. Until recently, I always threw away bathroom rugs when they started to look tatty. Now I just wash them--but I always run another empty cycle afterwards with some bleachy. Just in case.
I guess what I'm saying is that I'm all for sanitation. As long as it's not too much work, or, "What's a Few Germs Among Friends?"
As I've always said, you can eat off my kitchen floor. There's a lot of good stuff down there.
veg
A few germs are OK
I think its not good to try and kill every germ on earth. I think having a few bugs around keeps the immune system on guard, that is, if you are not exposed to the germs, how can you body build up a defense against them. We people are really filthy creatures if you sit and break it all down, so just do you best to maintain some semblance of order and don't think too much about the real nasty stuff (like all those dust mites that poop in your bed or the freaky little bugs that live on your eyelashes)
BTW, I've been known to grab the dirty fork thats been sitting in my worktub at the shop, rinse it off and proceed to eat my saimin. This is the most base behavior I have ever engaged in. THAT should give my white cells something to work on! So I'm not gonna worry about a few germs on the laundry.
I regularly wash underwear with shirts/casuals. And bath towels and wash cloths with kitchen towels and dish cloths. There're no creepy-crawlies coming out of my washer far as I'm aware. I'm 42 years old, no specific signs of ill effects thus far . . . although I suppose there are some people who would argue that point, LOL!
And anybody who doesn't want to have a meal at my house on grounds of contaminated kitchen towels, well, they just don't have to! :-)
And back at the Mortuary---------
First we had an old Maytag, then we took the old '63 Frigidaire Three-Ring down there.We threw everything into it, blood soaked (or worse) sheets, towels, car wash rags and occasionally one of our shirts or some other garment. Never had a problem BUT there is no doubt some of those things were teaming with some really MEAN COOTIES! Oh yeah, we used hot water, bleach, etc. But that was sufficient for cooties back when. Now those cooties have evolved into some really nasty things! Even though I am now retired from the business, I am really careful whenever (on rare occasions) I am called back in to service, because the rules of the game have changed.Everyone is super careful in the embalming room to make sure everything is disenfected as you work, cleaning behind yourself as you go. Sheets and towels are sent out to be cleaned by a linen service. Supposedly they use a steam rinse of some sort, but I doubt that would kill much nowadays.(They did not ask my opinion)! I am thinking the drying process helps a lot as most of these cooties depend on warmth and moisture, and drying out the garments would remove a medium for reproduction. I was reading one of the embalming trade magazines about rampant urinary tract infections in major hospitals, etc. They even traced those cooties to the drums of Betadine solution!!!!And that was over TEN years ago, so imagine how powerful those cooties are now! Oh well, just some thoughts. I will stick to a hot wash with Clorox for my dainties, and hope nothing hops out onto anything else!
I wash whites on HOT water with 1-1 1/2 cups of Tide w/Bleach (Purex is good too) and 1/4 cup of Biz, and I NEVER do mixed loads. I'm somewhat "anal" about the way I do laundry and OY...mixed loads are one of my BIG pet peeves. Judging by what Designgeek said, it's unhealthy if you combine whites with outer garments, which is something I don't do either.
Even when it is the smallest tabletop machine, I NEVER recycle water either. For each wash/rinse, I refill it. That's the best way to keep from infecting anybody. Bottom line: DON'T recycle washwater, no matter what it is.
Also, I find that having a tankless water heater saves time as far as laundry goes. We've had our Bosch AquaStar for nearly 3 years and now on-demand hot water is something I can't live without!
Any other "tankless" users here?
dryer heat
I always thought dryer heat for "an hour ISH" took care of that ............
Medically Speaking....
Okay... I have to jump in. As a Family Practitioner and as someone who does laundry and likes it.
Firstly, E-Coli is not fecal coliform bacteria. E-Coli is the short name for Escherichia coli. E-Coli is the most common subgroup FOUND in fecal coliform bacteria.
Secondly, there is not but one strain of E-Coli. There are many. We see new ones all the time. I believe the latest is Enteroaggregative E coli or EAEC.
Thirdly, you do not need to start nuking your under-roo's. E-Coli is a potent bacteria but structurally it's weak. ANY simple soap solution will break down it's cells down causing total distruction. As long as you are getting things completely wet and adding soap, you will be fine.
The reason meat must be cooked to 160* is because a high temp is required to break the bacteria down. If you want to bake your tightywhities in your oven at 160* for 10 minutes, aside from a small fire you'll have killed the bacteria.
Finally,
It would be a REALLY bad idea if we killed ALL bacteria on the earth. Your body cannot even fuction without bacteria. A special bacteria in the group known as probiotics exists in your intestinal track which actually helps you to digest food and kill toxins in the feces.
You may have noticed that after receieving certain antibiotics you'll have very loose stool for awhile. What has happened is you have recieved a broad spectrum antibiotic which has killed not only the bad bacteria but the good as well. It really didn't mean to, thats just it's nature. There are exceptions of course, such as Zithromax which is very narrow in it's scope of bacteria it kills (actually kills e-coli) and because of its method of action, it tends to cause loose stools.
E-Coli is responsible for a lot of infections. Many lung infections these days are caused by it, as are many of the infections resulting in Sepsis. For women, almost all urinary tract infections are e-coli related.
Keep in mind though that the strains of e-coli causing THOSE infections are NOT the same ones you find in human feces. The strains found in human feces will very rare cause you enough problems that you'll visit a health care provider. You may have some loose or bloody stool for a few days but it's self resolving and most people think they're just having a upset stomach. Only extreme or prolonged cases require treatment and the antibiotic Ciprofloxin works wonders.
This is not a health crisis.
It's not even a health issue.
But please, atleast don't wash your drawers with your dish towels... that REALLY freaks me out.
David Adams, NP
Board Certified, Family Pracitioner
Unless one is laundering cloth diapers, or linens/clothing from a sick room or person with a contagious infection, there really isn't a need to go overboard worrying about germs in laundry.
Yes, until recently whites and most everything else that could stand it was boil washed. But remember also until really after W.W.II when the first antibiotics became available, germs could kill. Small cuts and scrapes we laugh off today with some "Bactine" and "Band-Aids" could put one in hospital if not kill. So it made sense for housewives to be on their guard against germs in the home including linens. Housekeeping then was much about prevention of illness as it was keeping things clean.
With the average laundry water temp dropping to warm water, detergent makers have had to rely more on chemicals to "disenfect" than previously. Also with more fabrics and colours that cannot laundered with chlorine bleach, again laundry detergent makers have had to find ways around germ killing.
Having worked in nursing, am here to tell you that unless someone in your home has smallpox (highly common event until recently),or another highly infectious disease, shouldn't worry to much about laundry being "sanitized". Remember intact human skin is the body's first and best defense against germs entering the body via the surface area. One likely touches far more germ laden surfaces in the course of one's day besides their own laundry. When I took microbiology, we had to swap and culture common surfaces. If you really want to get grossed out, you should see what grows on door knobs, sinks (bathroom and kitchen), counter tops (same), desks and even someone's hands that has just been to the loo and swore they washed them afterwards. You'd never eat or feel the same in your own skin again, if you dwelled upon it.
Launderess
good point Laundress
Laundress, i figured you were a nurse all along. While we are on this germ topic. When hotel rooms and the articles in them, were recently cultured. What do you think the nastiest thing in a hotel room is???
Reply to air2903
My guess would be the bedspread---the first thing I do when entering my hotel room is to wrap my hands in kleenex and fling the thing in a corner far away! I always keep a baggie with Sporicidin wipes for the telephone and other surfaces.
Stay away from bedspreads!
Ewwww...yes, the dreaded hotel bedspread. I saw a book on hotels (forgot the name) by a reviewer and the first thing this guy did was take off the bedspread! Why? He mentioned that, based on statistics, hotel bedspreads contain traces of mucus, urine, feces, semen, saliva...the list goes on. Not to mention when these things ever get washed, IF EVER. Makes you REALLY want to pull the covers over your head...NOT!
Another reason I pull bedspreads off is from a little experience I had. Last Spring I strolled downstairs to do a load of laundry at a Courtyard (Mariott) in Abilene and wouldn't you know, the commercial laundry room was right next to the hotel's W/D facility. There was a newer TOL Kenmore set in there which wasn't too entertaining (but we were running low on clothes) so I started my wash and watched through the open door, the maids STUFFING 60 lb. Milnors; yes, some with bedspreads. Now I've seen Milnors in action loaded the CORRECT way, and it didn't look anything like this. The towels, sheets, etc. were not circulating at all, with no hint of suds. I thought...YUK!
And if this isn't enough...look here at this poor Wascomat stuffed with towels at The Riverwalk Plaza Hotel in SA.
--Austin
The Nastiest.
Id have to agree about the bedspread Gyrafoam, I know for a fact they are not laundered after every use. The absolute most bacteria and virus encrusted item,well maybe after fixerman's guess, was the remote control for the TV. Have a nice weekend folks. :-) alr2903
Not a Nurse
ALR,
Sorry, but only completed about half of nursing school then switched majors.
Basically as I had been a hospital junior volunteer, then a part time nursing assistant during high school, it was assumed by all a nursing career would be the most logical option at college. This was at a time when nursing was considered a "good" career for women as one could kept it up after marrying and having babies. In short paid busy work until you caught yourself a husband, and for those unlucky enough not to marry "well", a respectable career for a married woman.
Anywho, one morning whilst making beds with another student nurse, some hot shot young doctor I had known for years walked in and said "Good to see everyone doing what they are supposed to be doing". Well as the patients were in their beds sick, one could only assume that comment was directed towards us. Quickly realised I did not want to spend my adult working life, cleaning up poop,making beds, and other gross stuff, so I changed majors.
Still use quite a bit of my nursing and science courses in every day life though, so it was not a total loss.
Launderess
disinfectants
I seem to remember Lysol having a liquid version that could e added to laundry to disinfect things that couldn't be bleached. I wonder if it's still marketed? And I imagine there are other brands, too, both consumer and institutional.
Lysol Laundry Sanitizer
IIRC was a powder, and no it has not been on the market for years. You could use regular Lysol, but the "scent" does not leave your laundry or washing machine easily.
There are whole groups of chemicals one could use to disenfect laundry, but the cheapest and best for the buck is still chlorine bleach.
For most state and local health department, the standard used for disenfecting laundry is chlorine bleach. From commercial dishwashing to public laundry, bleach is it.
L
