Ebay Unimatic find
Really, this heavy chunk of cast breaks?
No you could shoot a bullet through many of those Unimatic mechanism, parts and they wouldn't flinch. John was being facetious.
The clutch torque spring and upper water seal are the only vulnerable parts I've found in that mechanism. Sometimes the pump impeller screw gets loose over the years causing the fan to rattle, but that is a simple fix of tightening the screw.
"I've had a couple oil-pump seals gone bad but after 50-60 years...  "
Goldang Frigidaire, pump seals failing after 60 years of somewhat continuous use? I'm shocked.....
