English Electric, Hoover & Rolls Repair clinic Weekend,,,,
chestermikeuk
May 29, 2001
7,410
Rainhill *Home of the RailwayTrials* Merseyside,UK
Following on from our "Large gathering" Halloween weekend 2016 it soon becomes apparent that our beloved vintage appliances often need a repair, tweek or masterbuild in order to keep them tickity boo and working !! You can see in the link thread that we often start repairs on said machines but have so much fun meeting up and chatting that we run out of time Sooo with that in mind we set too this weekend with a few of us to "Get To Grips" with a few key projects..
1. The follow on work with the very rare English Electric 4027 Autowasher found by Darren Aitch in a garden...
2. Finding out the cause of the Hoover keymatic timer not advancing after the great work already done by Steve and Richard..
3. Rolls Rapide twinny getting a new spin pump and overhaul
5. Electra Creda front loader overhaul and drum bearings and door boot/
6. Miele and Creda tumble dryers to get working.
7. Hoover Autojet dishwasher pipes sealed and testing
Heres Mathew (keymatic3203) and Richard (Ricky5050) getting to grips with the English Electric (based on the spacemates model).
Link to Halloween thread 2016
Consulting the "Hoover Doctrine or bedtime reading" to throw light onto the problem, all contacts , relays, cams and wiring loom checked, contacts cleaned and sanded, the machine operates, moves to the next sequence but not operating on the "Timed" portion of the programme.
Heres the timer in situ, its the 2nd generation timer on the sloping front keymatic, its a German made timer made by Holzer and its registration is AU..very advanced for its time as the terminal are placed in block connectors which make for ease of unclipping unlike later Crouzet timers which had all individual contacts..
Soo with the tub front and cast balancing ring removed, the thinking is 2 door boots, one fixed to drum inner lip and one through the front panel connected through the drum weight using a plastic panel which booth boots can be fixed and sealed to....of to the store we go - and the solution is ?
Yup you guessed it - a rigid plant pot cut to the right size...forming a rigid ring of plastic that both boots can be clamped to !! How ingenious is Dr Matt !!
And now the Electra Creada autowasher ( made by Creda for our national Electricity Board shops) is hauled ou, the back panel and drum removed ready for a bearing change, the seal had gone letting water into the bearings which had then been leaking rusty water all over the backplate , cabinet components and motor - time for a cleanup..
