European vs American "HE" Detergents
launderess
Jul 22, 2004
20,655
Whilst going though my stash of vintage and modern laundry detergents one wondered about the wisdom of using even low foaming products both modern and vintage. In particular am concerned about the Lavamat due to it's miserly use of water and often rather long cycles.
Well since one wanted answers not questions decided to see what there was on the Internet.
According to some authorities using high dilution detergents (products designed for American old school top loaders with central beaters)is not wise in modern front loaders in particular European versions. Theory goes that high dilution detergents are designed to work in lots of water. Thus one will not be able to achieve proper dosage to clean, keep soils suspended, prevent dyes from transferring, etc... buy using small amounts in a front loading washer.
I think the American HE detergents are formulated for cooler washing temperatures while Non-American HE detergents are formulated to handle washing in higher temperatures without foaming out of control. It amazes me with how the machines continue to get more water restrictive, we haven't seen a completely Suds-Free detergent like for an automatic dishwasher.
Malcolm
Suds
Same here for me where I live (very soft water) its the same problem with all brand leader powders, they are all very sudsy when it comes to rinsing and very often over scented for me.
That's why I switched to a supermarket brand that cleans aswell as Ariel and Persil but it is very low in suds and therefore rinses out very easily and doesn't really smell of anything.
Supermarket brand
"That's why I switched to a supermarket brand that cleans aswell as Ariel and Persil but it is very low in suds and therefore rinses out very easily and doesn't really smell of anything"
Which supermarket brand did you go for?
You would think that with the decrease in the amount of water available for rinsing that the USA detergent manufacturers would reduce the amount of suds in their detergents to almost nothing and work to make them provide suds free rinses at least by the second rinse.
This is one of the things that bugs me with the detergents readily available to USA consumers; that and the fact the all of them even those for darks and blacks contain optical brighteners.
Now along comes brands like German Persil for whites that is advertised to be used in 30C to 95C washes so nothing stands still.
Point one was trying to make in initial
Post was that "HE" or whatever one wants to call detergents made for H-Axis washing machines are designed to deliver their properties in low amounts of water and over often very long cycle times.
According to something one read online (a patent application?) high dilution detergents (such as those made for American top loaders of old) are meant to deliver full power, soil suspension, dye transfer prevention , etc... for wash times <20mins. Detergents for front loaders must cope with wash cycles that run thirty minutes or longer, thus remain active far longer.
Americans can get away with using high dilution detergent say like Tide in Laundromat front loaders because those machines have very short cycles IMHO. Also lack of a pump means suds lock while an issue is not nearly as much of one with domestic machines.
The other concern is that it is probably not possible to use "less" of a high dilution detergent in a front loader (say to control froth), and still achieve consistent results. Without enough product not only is cleaning ability compromised but soil suspension and etc....
Should be interesting
To see where the future will be with these detergents and the "newer" front loaders with even less water usage.Carnage may be just around the corner in the laundry room?
Supermarket brand
I was recommended to use Tescos own so I bought a small box to try it out, and haven't looked back.
I just don't know why the major manufacturers do it, I understand some people like scented powders etc, but suds???? many years ago a friend who was an industrial chemist gave me a small amount of lather inhibitor just half a teaspoon in with Ariel and that worked a treat.
ah well such is progress ;-)
Tescos own
Gary, how are you finding it? I used Sainsburys own powder once, but it wouldn't shift basic stains like deodorant marks from clothes. How is the Tesco one? I do love Tesco's own fabric softener, so might have to give the washing powder a go.
Tescos own
I have been using both the powders (colour/bio) for just over a year now and I like them both very much I have no problems with stains other than Bolognese sauce on T towels on a 60d wash so unless I do a boil wash I soak T-towels overnight in Tescos Bio powder.
But I did mention before that after 3 modern machines I now use a 33 year old Hoover machine with high wash levels and short programs and I am convinced it is down to this machines wash action and water usage that I get such good results.
But I cannot comment on its likely performance in a modern machine as back in the day I was using Ariel/Persil/Daz powders to try and achieve good results in the modern machines
Gary
I can recommend Simply by Aquados and M&S detergents. They don't create the excess foam like Persil does. However the new Ariel liquid is much easier to rinse and not as foamy as the gels!
Gary, What lather inhibitor do did you use by the way? The ones the major manufacturers use are not that good are they and they only start to work at certain temperatures like 60C. Ariel powder for whites gets very foamy when on warm washes but when you up the temperature to say 60C the foam 'dies' down.
Sainsbury's powder
Have been using the new Sainsbury's concentrated powder. Comes in a plastic self dosing jug. It is even more concentrated than Ariel future used to be. Smells like
megaperls, rinses well and has 5 enzymes. Made in the Netherlands? Damn fine product, and the most significant advance in the detergent sector we have had for ages. Yeah yeah I know, pods and all that......
Will post some pics if anyone interested. Am wondering if the brands will follow this and replace powder tabs, which I heard several years ago were on the way out.
Nick,
Believe it or not the majority of powders we have at the moment are the same, if not stronger in concentration that Ariel ultra was. When you compare the dosage of "big box powders" now to the equivalent in the 80's and early 90's there is quite a difference. The Ultra's, Micro's and Futur's failed to take off as the average customer could not get used to using 100 to 120ml of powder compared to their 250ml to 400ml dosage of the powder they were used to. Since the old compact powders were withdrawn mainstream powder has been gradually concentrated to a point where 50ml to 100ml of powder is the recommended dose in soft water.
P&G however have just brought out Ariel, Bold and Daz "compact" powders although not on the shelves in Edinburgh yet. Mind you we don't have the Sainsbury's compact either.
Hello Nick,
I would be interested in seeing some pictures of this concentrated powder by Sainsbury's. Always shop in Sainsbury's so hopefully will see it.
I think its good the detergent industry making products more concentrated as you don't really need all that much for a clean wash. I find even with hard water the recommended amounts are still too much for normal soiled clothes. Unless your covered in car oil or do an extremely dirty job I think the suggested amounts will lead to over foaming.
The bottle is self dosing, you tip it up and it dispenses 25ml at a time. I've edited this as I had got the recommended dosage wrong , pic to follow.
