Geoff's recent laundry room makeover has spurred me into action. I've figured out how to move things around to make room for a 2nd washer. Unlike most of you, I have no (none; less than any; zero; zilch
experience with this sort of thing.
The two washers and a dryer will be placed in a row. I'm not planning to run both washers at the same time---after all, there's only one dryer. The new washer will be a toploader; my current washer is a frontloader. I thought it would be fun to be able to choose between the two types. I'm thinking of getting the TOL Frigidaire, as it will match my current pair exactly. Also, they're very inexpensive, which will make the expansion financially painless. (Notice how I deftly bypassed using the words 'plastic-y' and 'cheap', LOL?)
Here are my plumbing questions:
1) Can I just get some Y couplers and add them to my current faucets for the extra pair of inlet hoses or should I have a second, dedicated pair of faucets installed? I always turn the water off when I'm done washing for the day.
2) What should I do about an extra drain pipe? I don't want to switch-out drain hoses every time I use a different washer. (I know what will happen: Eventually, I'll forget to put the right hose in the drain (most likely when I'm using the TL'er) and the carpeted family room right next to the laundry room will be flooded with 22 gallons of bleachy wash water). Is adding an extra drain pipe something my appliance installer can do or should I call the plumber and have him take care of that before the new washer arrives? The current drain pipe has a trap which leads directly into the cement floor, which is then fed to the floor drain.
Sorry if these questions seem wildly naive, but I don't want to screw-up anything. Thanks in advance for your advisement.
