Getting this out there
I've washed and spun waterproof items in my WFW72 at full 1200RPM with no issues of the machine blowing up.
Further, i've also washed and spun large comforters and king size duvets at 1200RPM with no explosion either.
Now on a different topic, the WP's that have been blowing up are the exact same ones in the category of a very certain spin cycle issue...I think you know what I'm talking about. It's happened to my duet along with some members Maxima's here too. That alone may have something to do with sensing something incorrectly prior to the spin cycle and the machine missing out on it. These WP's prior to spinning do a mini low rpm burst after balancing the load, sometimes it DOES skip that mini burst if it notices the load has no anxious movement. HOWEVER, there are rare loads where it skips the mini burst because it LOOKS like the load is balanced, but when it ramps up the tub moves violently even after the initial thrashing point of the tub.
IMO, if the machine surpasses and manages to get to 1200-1400 whatever max RPM, it MAY (or most likley, may not) pose a condition like this.
Judging by poking around, this has happened to basically every brand. Of course it would be higher on WP's side because they export more machines on a daily basis due to Maytag and Whirlpool being well known brands. Even an LG WM4270 has blew up during its high rpm spin.
But that IMO also doesn't give an excuse for them to be let off the hook. Sometimes I personally wonder if WP even knows what going on when something like this takes place. And if so, is that the reason why all their FL's now are 1200RPM?
I'd like to believe that. I really would. But, i came across a WFW70HEBW which has a max RPM of 1200RPM which looked to be the worst explosion I've seen out of all WP's.
Whirlpool does take a step in the right direction by replacing the units.
But another right but necessary step is STUDYING why this happened and to find ways to avoid this in the future. The best way to do this is to take the destroyed unit(s) and examine it and find things that each model had in some form relating.
I mean after all, look at how people react to Samsung washers now.
I bet their afraid of even walking up to them.
And rightfully so.
http://https//www.saferproducts.gov/ViewIncident/1619140
