Filter-Flo finally functioning!
turquoisedude
Aug 8, 2007
10,588
It's been a while since I have had the time to work on the collection and the current unpleasant situation at work has left me less than motivated, however after scoring that lovely 57 GE dryer, I managed to drag myself up and get busy on a machine fix that would help me keep my frame of mind more upbeat. And the machine I decided to tackle first is my prized 63 GE V-12 filter-flo washer!
I got the machine last May and although in remarkable condition, I discovered a baffling leak that appeared to be coming from the transmission. I was more than a little puzzled by this....
Well, thanks to the inspection camera hubby got me for Christmas, I found that the leak was actually coming from the tub seal above the transmission. No coincidence either that even in the GE Washer Repair-Master the number cause of a water leak was suggested as the transmission boot!
Now, I have always been a little intimidated by GE machines (the trauma inflicted by the repair person who said that they'd have to break the agitator to fix an oil leak on the much-revered V-12 of my youth had stuck...).
Getting the agitator off was a non-issue on this machine, but then there was this tub boot 'collar' that had me stumped...
Well, I learned that this part is not really even necessary but that if one was patient, it could be pried out with the help of a small screwdriver (and thank you again, combo52 (John), for your guidance and advice!!)
With a small screwdriver and an assist from the remote camera, I managed to free this in just a few minutes!
And there's the tub bolts! I had a slight moment of panic when I looked at the bolts and found they were not standard hex-head ones. But one of hubby's socket sets had the right kind of socket and they came out remarkably easy. I was most encouraged!
Now the tub lifted right out! Didn't have to stand in this one to loosen it... LOL
But geez those GE tubs are heavy! I managed to remove it alone somehow.
Now we can see the culprit - that tranmission boot may look good, but it's just putting on a good show for the camera...
Exhibit 'A'
There's the proof of where the mystery leak was coming from. Tub boot - you are sentenced to the trash!
I'd ordered a replacment boot back in fall when I knew I'd be getting the 57 GE washer - and it was a piece of cake to re-install!
TIP: to help properly seat a new boot, press the middle of the boot as you push down on the edge that goes over the lower lip. That saved me a good deal of cursing!
Not quite done....
When I had been inspecting the washer with the remote camera, I had dectected another leak from the side of the tub - this opening was the apparent source. Not wanting to have to remove the tub at a later date, I gave this port as well as its twin on the other side of the tub and the drain opening a coating of high-heat silicone. Great stuff, but I had to wait 24 hours for it to cure! [this post was last edited: 1/27/2013-15:12]
Yep, I even figured out that I should do this first water test BEFORE re-installing the tub....
As my father always asks when I come up with one of my hare-brained schemes, 'Are you sure ziss vill hold vater?' Well, ziss von does!! LOL
Best of all, the floor was DRY! Not a leak to be seen. I was doing the 'happy dance' around the basement, what can I say...
The re-assembly went well - but I did need hubby's help to get the tub back in! Those tubs are heavy! So with the tub back in, 'activator' back in place, and lid snapped back on, it was time for a second thest test. I am thrilled to say that it passed!
The GE Filter-Flo washer with its 12-pound load capacity swooped in to save the day! It worked wonderfully and my stars, this is possibly the quietest vintage washer in the collection!
Proud Papa
I can't express how happy I am to have finally found a GE V-12 washer! The only thing that could be better would be the matched dryer.... Oh wait! I have it in the garage and it's already been restored! Can't wait for the weather to get better to get that into the Ogden Laundry... Think hubby will notice?? LOL
Happy Dance
Yeah, I know that one. I did that after I figured out how to free the spin/agitate shifter mech on my Amp. I'm almost ashamed to admit that Dan witnessed this horrifying spectacle but still didn't care. The idea of tearing down that Amp had me worried.
Congrats on the repair. Now I want one of those cameras!
RCD
