Filter-flo transmission repair
Looks and sounds great! Agitation is quiet yet spry and it quickly gets up to top spin speed smoothly and quietly. Job well done.
Thanks!
Appreciate the kind responses! Never thought I’d have three fully-functional filter-flo sets and I love them all. This set was such a particular surprise to me because of the lighted dials. I had only seen a photo of a machine that had one of these but never thought I’d find one under my nose. That’s why I couldn’t part these machines out. They needed to be preserved and I’m so excited to have them up and running.
This site makes restorations like this possible and everyone here has so much knowledge they’re willing to share. I’m so grateful!
John
Yes, standard V-16 tub. The agitator for this particular machine was modified in an unfortunate way so doubt I’ll ever use it. If you’re willing to spare one then I’d appreciate it. Just let me know what I owe you for it.
Thanks!
Nice work Jon - a transmission rebuild is definitely intimidating, but not as bad as a car transmission - forget that LOL.
My Aunt and Uncle had a filter flow of some relation but I remember it had a lid that opened to the left.
Andrew
I second that;
Having studied several automobile transmissions both manual and automatic.
A conventional manual shift not so much, but a dual clutch manumatic or the newer 6, 7, 8, 9, or 10 speed automatics for sure. None have more than 5 to 7 forward planetary gear sets, but more valve body passages, clutch packs, and electronics than a 4 or 5 speed.
Aside from those, there are mega amounts of belville and thrust washers, bearings, spacers, fluid check balls, actuator bands, solenoids, plungers, diaphrams, pin valves, rotational sensors, etc. Many early ones had a both front and rear pump, which allowed a vehicle to be push started.
Various torque converter stall speeds, or the r.p.m.s at which the fluid coupling slips the least. A few later ones do still allow the vehicle to be towed with 4 wheels on the ground for infinite miles in neuteral. The Chevy Cavalier was one such through the 2006 model year. Computers and electronics have replaced the early and simpler cabled, electric and or vacuum modulated detent and shifting points.
Still with all this technology, some still feel much to busy up and down shifting to smoothly power the vehicle in order to maximize fuel efficiency.
Nice job
I’m just now seeing ur thread, great job on the restoration! Wish I knew how to repair the clutch’s an transmissions as u said they r getting harder to find! Maybe one day I’ll learn! I’ll keep an eye out for the agitator u need as well! I had a question though about the por 15 that u used to do the rust hole patching, what exactly is it called? I saw u had used a fiber glass cloth or something an put the putty on it? I also saw u used the preventing paint for the mild rust spots? Hope u can help, great job again! -Doug
Doug
Thanks! I’ve repaired a couple of horribly rusted outer tubs on GEs with both POR-15 and Bondo. Bondo is a resin that is mixed with an activating solution and brushed onto fiberglass cloth. If you’ve ever been on a brand new fiberglass boat before, it has that same distinct smell. Once the resin hardens it is extremely durable and waterproof so it’s perfect for washers. You can sand it, shape, and cut holes in it. Even paint it.
POR-15 is the name of the rust-proofing paint you can use to stop rust in its tracks. Inside these machines are common rust-prone areas such as the out rim of the outer tub, areas prone to trauma from an out-of-balance inner tub and anywhere there are hose connections or standing water. Simply paint this stuff on and it’ll bond with the rust and seal it.
Both of these can be found at both hardware stores as well as automotive supply stores where automotive paint and body repair items are sold.
I have two machines that literally were saved because of both of these items!
Let me know when you’re ready to work on clutches and I’ll do my best to support you. They’re not that bad really.
This is definitely a very informative thread. I just got my Filter Flo a couple days ago and it’ll probably need some work. But how many different Activator agitators were there? I thought the 3 vein ramped was the only one.
