Hi,
I have an old K.I.D. by Hobart that just recently stopped fully pumping out the final rinse cycle. When I run the next load the machine floods as it seems that there is too much water. In order to fully empty the machine I need to run the final drain cycle 3 times. Pump seems to be working fine, pumps out all other cycles completely...just the final drain seems to cut short.
I blew out the drain lines and got a new drain hose, no blockage there, seems to be a timing issue on the final pump out...is this possible?
Any thoughts or advice appreciated!
Scott
Scott
