FP Water temps
I've had my WashSmart since November and I can fill you in about some things. First of all, this machine only uses water temp selected during the initial fill to Eco Active stage, where it recirculates the concentrated water/detergent solution on the items for 4 minutes. It then finishes filling with uncontrolled cold water. So depending on the season and location, can be very cold or not so cold. The only cycle that fills completely with the temp selected is Allergy. I don't have a thermometer but I can tell you compared to the other machines I've used, the selected water temp comes out TRUE. Hot is dang hot and warm is almost what hot was on my previous machines. So it doesn't appear that they dumb down the temps. There is an option to turn on or off controlled cold only. I have controlled cold on now simply because tap cold water in NH in the winter is very cold. However like I said, the machine finishes filling with that and you can't change that, aside from using Allergy.
To be clear, this is NOT an HE machine. It fills completely with water with complete manual control over load sizes. The auto load feature works surprisingly well and does use less water, but not low water by any means. From what I've noticed, auto will pick a load size roughly 1 smaller than if you selected it manually by using the load size guides on the agitator. Sometimes I've had to pause it and select the size manually (which is great you can do), just because I wanted a little more water. It's a very versatile machine.
Overall I've been very impressed with this machine. It's cleaned the dickens out of everything I've put in. Granted my stuff doesn't get that dirty but I've had some cat puke incidents on my bedding that came out no problem.
Mine did come with a 5 year warranty. Overall reviews are very positive. I did have 1 person comment on my YouTube videos that he had many problems with his, but I know 2 people personally that have had this machine for going on 10 or more years with no problems. It's a very simple machine actually. Even the suspension rods are easy to fix.
Hope that helps.
