Fisher&Paykel AquaSmart WL37T26DW1.
Control panel or board glitch.
Whenever the machine experiences a power failure. The double dispenser config still says softener but when I go to select Softener on. It pulls up bleach dispensing. Resetting the config by scrolling to triple dispensers or not set and saving it then going back corrects the issue. Any idea why this is happening? Is there a coding in the valve or something or do I have to swap the valve wiring? I don't want to cause destruction so I am asking. The motor controller sometimes runs warm in a cycle. Is it about to die or is it normal. My Intuitive's MCU almost never gets warm. Is it because Phase 7 has more power or is it the SmartPump?
I don't have any specific suggestions.  Display and/or motor boards have non-volitile memory to hold machine configuration when disconnected from power.  Cycle status is also continually written/updated to memory for auto-resuming operation upon power restore after a failure.  There are fault codes for memory errors.  Have you checked if any are recorded that may not be displaying during operation?
Solenoids are monitored for faults via the electrical circuits between them and the motor board.  The valves differ physically on flow rates but the solenoids are all electrically 24VDC and 64 ohms.
I've never paid attention to motor board temperature, can't say what's normal or abnormal.
