FL Washers and Rinsing
roscoe62
Dec 9, 2010
327
Canada
So there are a number of machines to choose from when purchasing a front load washer, which one(s) are known to be better for rinsing based on your experience.
Tks for any input :)
Here in the UK it will have to be - Hotpoint Ultima. (2 very deep rinses on cottons, and add up to 3 extra - gives 5 in Total) - Water at least half way up the drum, with full loads.
I am not sure about the Canadian market - might be worth considering LG with allergy rinse - which is a 40C final rinse which rinses out all the residue?
40*c Final Rinse on LG
I dont really get the concept of a 40*c Final Rinse, wont they clothes come out of the washing machine warm, instead of cold?
Commercial Laundries
Have been rinsing at 100F for ages, though some do rinse in (tap) cold water as well. Laundromat machines are usually set for tap cold but have seen some where the first rinses are cold but some hot water is added for the final rinse. Can only assume the latter is to help dispense fabric softener.
Warm water rinsing (90F to 100F) has been around for ages, even after soap was replaced by detergents. There is some school of thought that the warmer water helps remove more residue than cold. It is also slightly better for any rinse products (starches, fabric conditioners/softeners) than cold water. Of course *cold* water can vary by local climate and time of the year. Ice cold water probably does not rinse as well as 85F.
Is there a pro to rinsing in warm water? Ok..I guess this will sound silly but I always thought that cold water would rinse clearer, hence breaking down more soap, etc....
I don't know of any new front loader you can buy that will let you use warm water to rinse.  At least not in the USA.  I guess these might exist in other countries though.
Warm Water Rinsing
It was common to have at least one or two hot rinses, followed by several warm or cool/cold when doing laundry with soap, by the 1970's when detergents had nearly totally replaced the former, (tap) cold water was recommended to save energy. This was largely for domestic laundries and you can see this taking hold as fewer and fewer washing machines were sold with "warm/warm" or "hot/warm" cycles.
Commercial laundries in the United States by and large use central hot water supplied from a boiler and mixed at point of use for proper temperature. The other option is to use steam supplied from a central system to raise water temps to the required level.
Using centrally supplied water allows faster through-put as there is no time lost waiting for water to heat. It also makes possible warm water rinses as the machine is plumbed to both hot and cold water.
For commercial laundries there are several reasons why they would use warm water for rinsing. The first is that again given various local climates *cold* water could be very chilly indeed. That would leave laundry "cold" and thus more energy is required of the ironers or dryers. How much more energy probably has been factored out and available to those whom need it. Consumer Reports long as stated that while placing laundry rinsed in cold water into a tumble dryer increases energy use for the latter, it is still cheaper than using warm water rinses.
Natural textile fibers much like other things expands and contracts in relation to temperature. Warm and hot water rinsing in theory allows greater removal of chemicals and soils than cold. Again this is going to vary by local water temps and other factors such as chemicals used in the laundering process.
Historically American commercial laundries use chlorine bleach for whites and or colourfast loads. This is usually done in a separate cycle (first rinse) at hot water temps (>120F) and proper pH (alkaline) levels. Hot water not only causes a faster reaction time of cholorine bleach, it also causes much of the substance to gas off which helps to reduce the residue in fabrics. My guess is that following a hot (>140F) wash with a hot bleaching cycle with a cold rinse would not only cause textile shock but suddenly cause fibers to clamp down trapping soils, bleaches, residues etc to be trapped.
There is also the fact various chemicals added to the succession of rinses (anti-chlor, fabric conditioners/softeners, starches, etc...) dispense and or work better in warm to lukewarm water.
Finally remember reading somewhere that warm water loads are easier for washing machines to spin/extract since they are "lighter" than cold. One assumes this relates to evaporation rates and the ease of moving water at one temp versus the other.
One has tried warm water rinses on several loads in the Miele and notice more "gunk" is rinsed from the wash faster than with cold. Also the machine seems to ramp up to spin faster. Also laundry felt "dryer" at cycle end and yes they did tumble dry faster. Regarding wrinkles, didn't notice anything unusual and things came out of the dryer looking the same as when rinsed in cold.
LG
Many of the LG machines in Oz have a final warm rinse and having used one in a holiday let, it is an unusual feeling getting warm clothes out of a machine when your expectation is for cold ones...
As to if they actually rinse better in warm water, I would suggest that they do. Theoretically, warm water will allow the fibres of the material to open up and allow more dirt and/or detergent residue to be removed than if rinsed in tap cold.
maybe its true that certain contry keep there washers with a true warm rinse options like if you look at canadian front load washers made by whirlpool or maytag depending on the model they are mostly all cold water rinse but from my point of view eliminating the warm rinse option has been a mistake as when clothes are rinse in warm rinse would take lest time drying as when i do a load that is rinse in clod water it takes longer to dry as i need to rely on high heat when if the same load i wash would of been rinse in warm water i could dry the same load on medium heat and the load would come out perfectly dry so i think that in a way they should at least put a switch on electronic control boards even if its a manuel switch an option if we went a cold rinse on modern front loaders or a warm rinse with in a front load model made by whirlpool or maytag that would trigger the heater of the washer that would heat the water until its warm to luck warm so that the suds are truly remove (first rinse) other rinses + extra rinse water remains cold to prevent wrinkles. in my next reply i will be posting a pic of the washer i plan on buying in the near future as i plan on stacking the dryer on top of the washer. Sorry if the pic is a bit blurry but this is a close up of my 2004 whirlpool duet front load washer and its a 3 temp model hot/cold warm/cold and cold/cold when my mom and me bought this front load model in 2004 i wanted to have a model that has a warm rinse option in case i ever needed to use it ex bed sheets but its only a 3 temp model with no water heater.
It is important to remember that while the purpose of both commercial and domestic laundry is to get textiles clean, the former has different values and reasons for getting from start to finish in their own manner.
For instance it is optimal for flatwork and other items going to ironers/mangles not only to be extracted properly but a bit warm to ease through-put and cooling of the machine (thus energy use) by having to recover temps from handling "cold" linen. Of course the heating capacity of commercial ironer units vastly outstrips home units, but one assumes even the *small* amount of extra energy required to maintain temp from cold washing adds up.
Some laundries "pre condition" items by putting them into a tumble dryer before going to the mangles (their version of using the "damp dry for ironing" setting on tumble dryers)but again that is an extra step and additional energy use both of which cost money and time.
Warm Rinse
This could be the solution to my rinsing epic when it comes to towels.It seems to be the only load(s) I have most of the difficulty with when being rinsed.
One person I spoke to suggested as they do to just rinse my towels on warm rather than laundering with the full cycle and only use a complete cycle once a month with detergent, and a very small amount, since towels have soap,shower gels,and shampoo residues in them.
They also suggested I line dry them, although I don't know what a difference this would make if the towels have a residue on them?
In addition to relaxing fabrics so that the natural fibers open up to give up the residues of washing chemicals, the relaxed fabrics pack tighter to yield better water extraction in spinning.
I don't think you would be very happy with towels that are just rinsed and not washed. They would soon smell. We have dealt with deodorizing towels that were poorly washed and became an inadvertent biology project.
Please don't follow the 'rinse only' towel-laundering advice. Yikes. I wash towels with the Steam option on my machine, which provides a hot first rinse followed by a cool final rinse. I use less detergent on my towel loads, since I have a one-use policy.
Body Soap/Wash Product Residue On Towels & Wash Cloths
Bath linen should be washed in hot water with a good dosage of detergent to remove human skin oils,soils and other stains they come into contact with. Soap residue can be handled by using phosphates in the wash water. Failing that you'll need *HOT* water to open textile fibers so the gunk can be removed.
You can also "strip" out textile residue by using hot water and decent amounts of washing soda in a wash cycle,but you'll have to rinse several times and use a final sour bath to avoid hard and scratchy towels.
Biology Project
Well when one's laundry is headed for that lab I'll keep to a full cycle Thank You :)
In summer towels like anything else can be very difficult to clean simply because if not done in an appropriate amount of time mildew and or mold will start to surface with the help of the humid weather.Some of us have learned this the hard way :(
So since I have this problem with rinsing would it be best to reduce the amount of detergent or just do an extra rinse in warm as a trial, or both?
Like Ronhic said, we too used an LG machine at a small B&B style place (except it was DIY Breakfast). Clothes came out steaming hot, even on the "Quick" cycle (2hrs +).
That said, the machine was connected to an ancient Bosch Tankless Gas water heater, that was as loud as a jet taking off if someone threw a decent load on it!
@launderess
Will washing in hot water clear out the residue but leave the towels hard over time and will it also wear out the towels premature? And are you suggesting a warm rinse or cold rinse? My machine will not do a warm rinse with a hot water wash.
Tks for your help :)
