Flooded
Oh Glen I hope it has let up by now and is receeding. 12 inches of water!!!! was the dryer gas or electric? And did the water cover the motor in the F&P?
How will Granny's house dry out, how does on dry a whole house out after that?? I get 6-7 inches in my basement in the spring but everything as already mounted up higher so it just cleans the floor and drains away. I can't imagine carpeting after that.
Hope you are all dry and safe now.
jon
Jon, water didn't get *in* Granny's house, just the rear storage shed, the separate garage (which is actually on the lot next door that belongs to my parents), and the carport on front of the house. The utility area where the F&Ps are is the rear 1/3 of the carport that was enclosed some years ago. I didn't observe the level directly at the peak, but the debris lines indicate it would have taken two to three more inches to actually get into the house.
We were lucky. Other houses in the neighborhood that are on foundations instead of blocks did flood, as well as many other areas around town. Granny is on the east side of town. A business on the west side suffered 14", and the Middle School on the south side had 8 to 10" and is not expected to be cleaned-up to resume classes until after Christmas.
Yes, the F&P washer's motor was submerged, and I'm sure the dryer's was as well. And both of the KAs in the garage, not to mention my Superba dishwasher that is stored there. There was no water in the F&P dryer drum, but there was water in the KA dryer drum, due to differences in the construction. I don't plan on trying to run the F&Ps for at least a week, if not longer. I'm concerned that the GWL08 was still plugged in while submerged, and there is a degree of power applied to the motor, even when the machine is turned 'off.' I assume the SmartDrive motor is designed with safety features against water in case of a center seal leak, for example . . . but it remains to be seen what are the effects of the water. I'm sure the KA will have an odor from the sound insulation, that water was nasty/dirty coming across from the field next door. I'm wondering about taking off the cabinet and flushing it with clean water?
There was a similar flood some years ago, I think in 1994. It wasn't as bad all over town as this one, but about the same effect on the east side. Granny still had the Design 2000 and the 1972 Whirlpool dryer at that time, and both were submerged to about the same degree as now. Both of them ran perfectly fine after a good wait for drying out. They were still running in 1999 (five years later) when the KAs moved in.
Who makes that F&P Dryer
Hi Daddoes,
I'm sorry to see the mess, we got caught in the Floods in Victoria in 93 and I wouldnt want to go through that again. Again though washer dryer and fridge all worked perfectly once they dried out.
I was wondering if you could post more pics of the F&P dryer as in AU the F&P dryers are what the US classes as compact. (4.5kg)
Is it made by F&P or is it a rebadge?
Good luck with the cleanup
Nathan
http://www.fp.co.nz/laundry/dryers/models.cfm
Water Damage
Even though not appliance related be sure and have the crawl space under you grandmothers house checked for mold and fungus in a couple of months. Lived in Houston in the 70's and had a rasied house not a slad and had water get in and fungus started on the underneath had to have it sprayed to keep the fungus from eating the wood and making it crumble.
MY heart goes out to you.. During both hurricanes Francis and Ivan, my home in Asheville, NC was flooded, worse the first time than the second. I am just getting settled back in, but it will be a long time before life is back to normal. have a Roper DD washer and Kenmore Dryer and both work well, and both were flooded. My stove and potable dishwasher wheren't so lucky. I had one of the first D&M 18" portable dishwashers (kenmore) and it was destroyed. So was my 20" propane Tappan Range from the 60's. My freezer surived and my fridge did also, but i lost a good bit of appliance brochures and books, which had been aquired from estate sales and an appliance store that when out of busniess, and most everything else I owned. The most important things to me (my dog, cat, vehicles and myself) survived. My work gave me a good bit of money to replace what was lost and my parents picked up the rest. Again my blessings are with you..
flooding
Wow, it's like the movie "Day After Tomorrow"!
I see all this stuff happening on TV and in the newspapers and find it hard to imagine being in a mess like that since that kind of thing just doesn't happen in central Los Angeles
So the F & P's are in service and the KA's in storage?
