volsboy1
I have been thinking of a Frankenstein dishwasher for me to build.I am going to use a G.e. washer with a dial and put a larger motor in it add more wash outlets on it.I was wondering could the G.e. take that type of Amperage draw.I have two design plans.I thought the most easy way to go is just add another G.e. motor to and a tap into the main wash line.I would use one motor for the bottom arm and the other for the top wash.The new motors are cheap 25 Bucks on ebay they only draw 1.8 Amps.I picked up a 1/2 H.p. grinder Pump for 20 bucks at the Flea market its a Cap start and is a 50 Gallons a min output but draws 6 Amps. Would that over tax the controls on it.This pump can grind anthing but if I went this way I would haved to use a seprate drain pump because of the the drain diverter would not work I dont think because of the shear power of the pump.The G.e. is the best route because I can add alot more water with out it running out the door because of there set up.Does anybody have any comments or advice.Would 50 gallons a min going through the wash arms be to much I dont think so sence it would be split three ways.I was going to use the old metal wash arm for the bottom but it has that pop up tower on it.I thought about swapping it out with a whirlpool tower or just cap it off and make a direct feed for the top.I do like the tower design if its made right.
