Fridge designs
Natural draft
That is of course true. In fact, perhaps 5% of problems with fridges even today involve the sealed system. Most are the defrost, fans, cold control and of course if you have an ice maker, those are probably over 50% of "fridge" problems.
static condenser design
Does this type of design create more heat than other types? Or are they all about the same for heat transfer into the room?
Thanks,
Rick
Here's my FCI-20V
Since we're showing off our refrigerators, here's mine. It's a Poppy Red Frigidaire. Got it for $50 because the previous owner thought it was going out on him. It turned out to be cat hair and lint plugging the coil underneath.
And here is an up-close of the ice maker that I had to dig through an old appliance store to find and it too has always worked perfect since I installed it. Makes these great little 1 inch square cubes that are so much better than todays 'orange slice' cubes that are all you can find in any refrigerator brand these days.
In the US...
Okay, that is one sweet Poppy!
Here's the setup at our place; Amana 27, Amana bottom-freezer, and a classic Coldspot upright freezer. (side story- these are my parents, my fridges are in the basement in anticipation of my house construction)
Cool features on the '27, it's all digital with displays above the right door handle. Temp adjusts, Fast Freeze, door-open alarm silencer, etc.
Food in the left fridge, drinks in the middle, frozens in the right.
Cory
Hey Rick,
Static condensers don't do well in high ambient temps, like on a hot summer day. It prolly feels warmer above the refrig because heat rises. A fan cooled condenser will do well in a hot enviroment and feel cooler because it exhausts the heat from below and into the room. Though static condensers are more energy efficient because there is no fan involved, and it doesn't draw in lint, pet hair, etc. Hope that helps!
Hey RickR, I LOVE that cabinet design in your kitchen! Are those custom built, or were they modular ones . I am looking for something like that to redo the particleboard junk in my kitchen.
That fridge works perfect in there with them too!
I agree with you pdub on those ice cubes. Those half-moon cubes have been another one of my pet peeves with fridge designs!
I KNOW you all have experienced ice-blockage when sipping on a drink eqipped with those half-moon ice cubes. They will get horizontal in the glass, and since they are the same shape as the glass, will block the liquid from flowing into your mouth....then the worst happens. Enough liquid gets dammed up beind the cube, and then the dam finally "breaks" (the ice cube moves) A flood of drink ends up into yor face, all over your clothes and everything else!
responses
"Most fridges here now, have SOME condenser tubing around the door frames, this is to reduce moisture on the outside of the frames. Older fridges (our Norge AND GE both have this) had electric heaters in the frame, to do the same (reduce moisture)."
There advantages and dis-advantages to both systems. Running a condensor tube abround the door frames makes use of the heat to prevent sweating BUT, that heat leaks back into the refrigerator since it's not switchable if anti-sweat is not needed. The electric heaters in the door frames use more power, but can be turned off when not needed.
"Does this type of design create more heat than other types? Or are they all about the same for heat transfer into the room?"
No, same amount of heat would have to dissipated into the room from either type of condensor
"Static condensers don't do well in high ambient temps, like on a hot summer day. It prolly feels warmer above the refrig because heat rises. A fan cooled condenser will do well in a hot enviroment and feel cooler because it exhausts the heat from below and into the room. Though static condensers are more energy efficient because there is no fan involved, and it doesn't draw in lint, pet hair, etc"
Again, we have advantages and dis-advatages to both types, true, the fan-cooled condensor would be more efficent in high temps, and allows one to put the refriegerator flush against teh back wall, but then, as was mentioned you have the dirt collecting problem, another part to use energy, make noise, and eventually fail (the fan). The static condensor on the back avoids those problems, but then one must remember to spce the refrigerator away from the back wall, and if cabinets are overhead, that there's a space between the top of the refrigerator and the bottom of the cabinets for heat to escape. People also tend to put things in that space, blocking heat escape.
"Food in the left fridge, drinks in the middle, frozens in the right."
So are you saying the freezers in the side by side and bottom freezer fridges are empty and all the frozen food is in the upright freezer? :-)
Now that's a refrigerator!
Patrick:
I want a poppy red Frigidaire and I want it NOW!!!! :-0
Wow: That fridge is way too cool! I can only hope and pray that I stumble (did anyone say serendipity) onto such a great find! :-)
They are out there...
Venus-
I saw one last month on craigslist for the Seattle, WA area. It was a 3 door (split freezer) side by side in Poppy Red and they only wanted $75.00 for it. I looked again today but can't find it so they must have sold it and removed the ad.
Thanks for the compliment. I knew only this group could really appreciate it like I do.
cybrvanr
The design of current icemakers out there has also been a pet peeve of mine. I don't understand why someone can't redesign a better ice cube shape to come out of their ice maker.
Static cooling fin design
Thanks for the info guys. I guess it's six of one and half a dozen of the other as far as heat transfer into the room goes. Guess I'll keep mine. I did pull it out about four inches from the wall last Fall when I clean under it. Perhaps that will help this Summer.
By the way that Poppy Red is just the coolest!! Love it! Why do the make only ugly colors now??
I agree with you guys on those cresent shaped ice cubes. They have used that same design since the 1960's! My 77 Kevinator's factory icemaker makes the cresent shape as well. They are slippery,and I am forever dropping them. They are also devils to pick up off the floor!
Rick
icemaker cube shapes
Didn't GE's have a design that had little rods in the bottom of the molds that pushed up the normal-shaped cubes, then a bar would sweep them off into the bin? Do they still do that or did they succumb to the crescent shaped thing?
My kitchen 1887-2002
Steven the kitchen and cabinets are my own design. A contractor did the work,and a custom cabinet maker made the cabinets according to my design and specs.
I had hated the kitchen in my house for 25 years or so,and had thought about "my dream kitchen" for years.I had just one ft. of counter space on each side of the sink. After the lead pipes started to leak above this room and ruined the ceiling,I had my chance to make it reality.You can see the little Hotpoint fridge in the corner of the pantry. It was made for an ice box you see.
This is before. Thanksgiving Day c-1988 or so.
and then it looked like this..
I had the contractor tear the wall out,so the pantry could be a part of the kitchen, and the ceiling tore out also so the lead pipes could be replaced with copper. Then it looked like this.... Even though it was a mess,it STILL looked better to me!!! LOL!!
Meanwhile the rest of the house....
LOOKS LIKE THIS!!! FOR FIVE MONTHS NO LESS! Thats when I learned that when contractor say's it will take five weeks,he's REALLY saying five months....
The whole interior of the house was like this all Summer.
Then it looked like this,and I was HAPPY again!!
And also $20,000.00 poorer... However it is worth it to me. I have granite countertops,and ceramic floor and copper plumbing.It will all last the rest of my life and them some. I bought a used 1977 Kelvinator fridge to go with it,because I hated the junky new ones and that was before I found this wonderful web site.
Thanks,
Rick
Microwave Radarange
Veg the microwave is a 1979 model. Touchmatic 2..... Photo courtesy of our lovely friend Bethann!! (:
Rick
dishes
In the pic of the old kitchen with all the people, dost I see a Corelle "Butterfly Gold" coffee cup on the right counter? God, we're a sharp-eyed bunch :-)
My whole dish set is that design. They don't make that pattern anymore, had to fill out my set off of E-Bay.
