"Most fridges and freezers here have the condensor mounted all the way round the fridge cabinet, the outside of the fridge gets quite hot.
Is that how its done in the US or is the condensor still underneath or at the back?
With the condensor built into the whole cabinet, you can place most fridges into a confined space."
Most fridges here now, have SOME condenser tubing around the door frames, this is to reduce moisture on the outside of the frames. Older fridges (our Norge AND GE both have this) had electric heaters in the frame, to do the same (reduce moisture). Of course just running more condenser tubing in the frame doesn't require extra energy. However I think pretty much all fridges here, with the exception of mini fridges, have a traditional condenser. Freezer only units are a different story. BTW it would be bad to put a cabinet mounted condenser fridge in a confined space, the cabinet has to exchange the heat to the air, can't do that with walls next to it. But I have no idea of Australian designs, might work fine in a tight space, not sure lol.
