Frigidare Built FL washers
Nice usable laundry room set-up, you should be able to turn out lots of clean laundry per hour.
They sold MILLIONS of these machines between the Frigidare, Gibson, Kenmore and GE names and they are pretty decent performers. The washers had more than their share of broken spiders and bad bearings, the spiders are thinner than most FL washers and if you use too little detergent, too much fabric softener, in cold water and no bleach they corroded and broke often. The same user problems contributed to seal and bearing failures. Over sudsing and packing the machine never likely hurt any of these washers, or any other modern washer.
We work on these dryers almost daily, they are an OK dryer if you are not a heaver user, I estimate that they have about 1/2 the usable life of a WP built dryer, or about the same as newer GE dryers. Weak areas are the front and rear drum bearings, motor, idler pulley, heating element, and valve coils on the gas models. The good thing about these FD built dryers is that they sell a dryer rebuild kit that contains the F&R drum bearings, belt, idler pulley assembly for less than $50 retail so it really helps to keep these machines repairable without breaking the bank.
