dustin92
Our beloved Maytag Jetclean bit the dust a few days ago, and while it's probably repairable, it's not financially possible right now. The same evening, I found a working Frigidaire dishwasher on Facebook, curbside for free. Picked it up the next morning, and while it's definitely seen better days, and had some pretty bad mineral buildup inside, it seems to wash pretty well, and surprisingly quietly. I had to clean out both spray arms (neither could get enough water pressure through to rotate before!) But it was mainly hard water mineral build up. Yes, it does wash one rack at a time, and sounds like a drain pump for the wash cycle, but I've only had one dirty dish come out. Definitely not the same build quality as our Maytag, but from what I see Frigidaire is a lower price point than Maytag. I'll post a couple pictures when the current wash is done, but from what I can find online and from the manual it was built around 2003. The only real issue I see is the bottom rack is pretty rotten.. I assume from prerinsing and over use of detergents, maybe high heat cycles? I'll be happy if it gets us through this apocalypse until I can repair the Maytag or find something better! But honestly, I haven't heard a lot positive about Frigidaire dishwashers and curious to know why?
