Frigidaire Dryer Help
countryford
Nov 28, 2006
1,723
Austin, MN
Well I had to change the cord on the Frigidaire dryer, and decided I should go ahead and take the back off to check the belts. Well it appears that the belts that were on it, are original. They have a date stamped on them of 3/52. Anyways, they have a Frigidaire part number of 5433778 listed on it. Does anyone know if there is a cross reference part number, or know of another belt I can use on it? Thanks.
Belts for an Old Frigidaire Filterater Dryer
Hi Justin, you should be able to use any good quality belt that will fit, they are both the same size so this is an item that you can get at the hardware store, call me if you need any more specific parts for this dryer, John.
Well I checked the local appliance store and found the belt for $26 each. I decided to wait. I then checked Home Depot, and they didn't have one the right size. So I went to Autozone and got 2 for $8 each. Both installed and a new cord, and it should be ready to check for its operation.
