frigidaire spin tube dishwasher pics
rollermatic
Oct 10, 2009
2,068
columbus and milford ohio
this is the most unique dishwasher i have ever bought. a spin tube frigidaire with a date of nov. 1st. 1963 stamped on the pump! what a nostalgic, historic, and tragic month nov. of 1963 was!
i bought this on e bay several weeks ago for about $129.00 and drove to and back from chicago yesterday to get it.
here are some pics.
back of tub
showing the main water line from the pump which is a hose about 1 1/2 inches in diam. smaller line to top sprayer feeds off of it.
the fill water line also comes in thru the back which i have never seen before.
and
another.
this area was dirty but later cleaned up very well. due to all the hoses and intakes coming in thru the back i was careful not to lay this one down on it's backside like i usually do.
this screen sets directly over
the pump intake in bottom of tub. it is actually 2 screens and the top fine particle screen is sucked down on top of the course plastic screen during the washing phase.
it rises back up during the drain phases so food particlesd can escape down drain. pretty unique!
bottom course filter
in place without top fine particle screen. top screen rides on that spindle using a spring to give it it's up and down bounce.
plastic device to the right with the 4 screws is a pressure switch water feed.
from the bottom
this is pump before cleanup. it has a cast iron pump housing but the impeller is plastic.
definate water leakage around that pressure switch funnel that bolts to tub bottom with 4 screws.
