Frigidaire
scooter76
Active member
Nov 30, 2010
41
Did they really make this laudry pair? I have the stove (RXE-39P) in my kitchen, but have never seen the "High Fashion" laundry pair outside of this ad.
I had the actual electric dryer and was hoping to find the matching washer but never did. The style was awesome and the dryer actually,like that one I have now,had 2 tumble speeds.The washer had "infinite speed" agitation and spin controls that allowed you to "tune in" whatever you desired from soak to 350 BPMs and from a mere 75 RPM spin speed to a whopping 1050 RPM Rapidry spin. I did have their step down model that was the same w/out the storage.It worked fine but had some serious clutch issues and,after three replacements of that expensive part($150 way back in the early 80's)I had to strip the unit for parts.I laughed every time I saw the new models on display at Reed's Refrigeration because the agitator cap on them had a silver (aluminum) emblem instead of the blue plastic one on the lower end models.It would drive me bananas when i would go to any "Coin Clean" commercial Frigidaire Laundromats and see the customers using the Deep Action Agitator caps for ash trays!!! I would always get them off machines at the junk yards and super glue them on to the commercial machines to keep them from being destroyed.
That's awesome...a bit over the top!! I wonder how the control circuit worked. Did the rheostats on the control panel directly vary the voltage to the motor, or was there a control module of sorts in between? Sounds like something you would never find parts for anymore.
I assume
this is the WXL High Fashion model that I've heard of that I know nothing about, but had the variable speed drive mechanism in it. I'd love to know how it worked.
Huh, I wonder if it had a DC motor... that's the only electronic way I can think of that infinitely variable speed could have been implemented at that time.
Unfortunately, one of the few Frigidaire washer manuals I am missing is the 1967 Tech Talk Supplement (Vol 67, No. 11) that covers the late release L series WXL washer. The WXL was released for sale much later in the 1967 model year, requiring a separate parts sheet and Tech Talk article to be published for the new variable speed washer. It should also be noted that the N series washer service manual also covers the variable speed clutch.
GM made a total of 4 varriable speed machines from 1967 till the release of the 1-18 washers in 1970: WXL (1967), WXN (1968), WCDXN (1968), WXP (1969 model year). These were TOL/Custom Imperial machines with the exception of the WCDXN Custom Deluxe. I guess the marketing folks figured that if they had an optional rapid-dry CD machine, they may as well stretch the cost across as many models as possible.
Years ago I stumbled upon the late 68/early 69 Tech Talk supplement for the WXP, WCDXN, and WXN washers. Fascinating what GM attempted with a magnetic clutch, a few transistors, and a low voltage transformer. The washer does indeed utilize the familiar 120v motor found in other Roller-matics.
While the supplement below does not cover how the clutch works, a service tip is described, indicating that if you remove the control module circuit between the control coil and apply straight 12v to the control coil from an external source, the machine should spin/agitate at full speed. It appears the motor shaft slides through the center shaft of the clutch assembly, and attaches to the clutch driver plate. The clutching action happens between the lining and the driven plate. The driven plate has notches evenly spaced on the parameter of the pate, providing an on/off signal to the speed sensor. I'm not electronics/electronic clutch expert, but I suspect the control module reads this signal and appropriately adjusts a pulse to the clutch coil until the preset resistance is similar between the speed control from the control panel and the speed sensor. That still doesn't account as to why full 12v at the sensor would provide full speed unless a fully charged coil allows the clutch to spin freely and a varied voltage would cause the magnet to drag the clutch for lower speeds. LOL, now I'm thinking out-loud!
Mag clutch experts - please correct me as I'm much more versed in standard mechanical clutches.
I've included a few scans below. If Robert would like I did scan the whooping 16 page manual in case there is interest to have it posted in the service manual section of the site.
I'd love to find and tear into a WXL or WXN someday, or see one in person. [this post was last edited: 12/2/2010-22:01]
