When replacing this item (WE1M462), does it simply press down onto the drum shaft? The worn sleeve pulled off easily enough, I suppose because it's worn, but the replacement doesn't go on so easy over the retaining ring at end of the shaft. I'm leery of forcing the new sleeve for fear of cracking it. Is the retaining ring supposed to come off? I don't see an obvious way to do that.
