GE Filter Flo Tub Boot
jessed
Jan 11, 2017
147
Saint Marys, Pennsylvania
I am looking for a new tub boot for a GE Large Capacity Filter Flow washer. I cannot seem to find one available anywhere.
The machine leaks from the bottom only during spin it seems
Thanks
Oddly, the GE Filter Flo pumps and OEM tub boots have skyrocketed in the last few years. There are a few options out on ebay at varying price points, but be prepared to shovel out a handful of cash for a GE OEM boot. IIRC, a club member offered up a boot on your other inquiry about this.
Before you buy a boot for the machine, are you 100% certain that it is the tub boot that is leaking? GE outer tubs often will rust - either pin hole leaks OR rust out around the drain outlet hole, where the rubber flashing of the drain to pump hose fits against the tub.
Pull the wash tub and inspect the outer tub first to make sure that the leak isn't from another source before buying a boot.
WH8X246: https://www.ebay.com/itm/226400018416
Ben
I am planning on tearing into it soon. I hope it is nothing major as the machine is in an upstairs apartment r a dear friend of mine. I really don’t want to have to move it.
