Hello folks
I recently came into a 1956 GE 2 DR top freezer. Its actually in good cosmetic shape but does need a new cold control and a few other things. I have a couple questions I'm wondering if I can tap into some of the expertise in the group for.
The first one may be a dumb question. The fridge came with no levelling legs - did GE use a unique size for the threaded end or were they some kind of special item?. I tried standard levelling legs and they were too big for the holes in the back corners and too small for the holes I believe they are meant to go into on the front.
My second question is the appropriate replacement for the cold control. The original is WR9X114 - long ago NLA. I've attached the specs of the original and also a chart of various Gemline replacements. From what I've researched, the recommended replacement is GC404 or GC403 however GC409 looks to be a closer match with the original capillary length - any opinions on which would be the best sub? I can't see where the original was clamped to the evaporator in the fridge section as it was removed long ago. I have to use the original screw in dial due to where its placed in the fridge section
Or is there another one thats not listed here that might be better?
Thanks so much in advance for any advice.
