GE Monogram Dishwasher leak
jjsunshine
Active member
Dec 27, 2010
26
Northern California
Hello, the door on my GE MONOGRAM ZBD7100g03SS has a leak that I cannot fix, it drips on the right side. I have replaced the tub surround seal and also the seal that sits on the base of the tub against the door. I tried putting some epoxy on the channel that holds the door seal *right where the rack glides* as it doesn't sit flush against the side bottom corner of the tub......water is still dripping out. Thanks for your help and suggestions!
I finally figured out the problem. I had to replace the channel that holds the door seal in place. Pretty easy fix, they are held on with 3M tape and a few screws. No more leak! Hope this helps someone.
