GE Potscrubber Long Wash/Rinse
washer111
Apr 11, 2012
2,220
Looking through the manuals for older GE Potscrubber 1200 (namely the "S" model), I noticed that "Potscrubber" engages an extended main wash and final rinse.
How is this achieved? Is there a 2nd timer motor which times the disengage period for the main one, or does a water temperature thermostat stop the timer, but allow continued washing during the heating phase?
On a side note, its odd that models after the "S" decided that "Light Soil" cycles required 3 pre washes, whereas the "S" would actually skip some of them - I'm assuming it either paused for this time, or maybe rapid advanced.
Thats an interesting little device you speak of. I suppose you could always add one to any mechanical timed dishwasher then, if the results weren't too good, couldn't you?
Like on BOL models like the Asko's I always ramble about, you could make a "HEAVY" switch, and use that, but watch out that it doesn't overfill the machine :)
GE had a close to TOL dishwasher with controls on it to vary the wash time, the dry time and maybe something else. Each little dial went from a few clicks to the left of Normal to decrease the time to a few clicks to the right of Normal to increase the time. It was in the early 70s and I looked at it in a department store so I don't remember it very well.
