GE Profile Combo Washser/Dryer at KBIS 2023
GE Combo...
"why would you buy 2 of these when you could just buy a nice set??
Here's one very good reason: Not having to deal with cleaning out a long dryer vent run that eventually gets clogged every 6 mos to a year"
True , My question as to why is based on a Full Size heat Pump Dryer if space for two units , no vent required !!
I keep forgetting about the heat pump dryers...
Yes, that would be optimal...buy a regular FL washer and a heat pump dryer INSTEAD of buying 2 of these.. Personally, I love having a regular dryer..
I'm one of the RARE people that don't have to have a matching set..(I just need them to be the same color) don't get me wrong. I would prefer matching.. but for whatever reason it doesn't bother me... which is very strange because I'm usually OCD about things like that.
Additional GE combo review
Reply number 146, thanks for posting this Pete.
This poor guy has so many frustrations. He’s so upset that he spent this much money he really has no idea how machines work he’s just trying to make money online with videos.
Basically all condenser dryers leave clothes a little bit moist. This is actually good for the clothes rather than whining about it for 15 minutes. You should just fold and hang up his clothes and be happy.
For somebody doing a review like this he has no idea how things work, it’s easy to schedule a service call for this type of product although I don’t think there’s anything wrong with it. The little bit of lint removed did not make any difference in its performance.
Seeing their loads I am 90% sure that's just user error.
You just can't dry a 3cuft load in a 4.5cuft drum the same way you do in a 7+cuft dryer.
Keep in mind these are even less accurate in sensing as they have to use basically thermostatic auto dry with a very low temp system.
My partner ended up with a compact combo through some coincidences.
It can dry very well - if you keep in mind what you are drying and how much.
If you have basically 100% even thickness through out the load you can load more.
But especially on items like jeans, sweatshirts and the like with pockets and seams, you just HAVE to leave room for proper tumbling and airflow.
Combine that with heat pump dryed clothing tending to feel more moist you just will have people not understand the appliance they are using.
New GE heat pump combo review, reply, number 146
Hi Pete, thanks for posting, I actually watched the whole review. It’s a little bit painful the poor guy that did it. I’m sorry he’s acting career didn’t make it.
I think the main problem he’s having is he’s having buyers remorse about how much he paid for it and when you have space for a full-size washer and dryer, he was a fool to give up the Maytag dryer, he just got rid of a pair of machines that cost about $1700 to buy this machine and he thought it was gonna do everything. He should’ve kept the dryer to have when the occasionally want to do really large loads, or if they were in a hurry, rather than all the whining, he never mentioned how much water and electricity this new machine is saving either maybe he can’t figure that out.
The main problem he’s having with drying is the loads may be a little big but the machine is tangling the stuff, and this was my fear. You really can’t have a dryer with a slanted drum , it’s bad enough to have a washing machine with a slanted drum but you can untie things before they go in the dryer, but a combo I think is going to have problems with this. This may be the biggest flaw I’ve seen in this GE yet.
The little bit of lint that he pulled out of the lid, filter, housing, etc. was not causing a problem , but he feels good by cleaning it. You’re only supposed to clean the lint filter every two or three loads every time you remove the filter lint gets past the filter assembly it’s not necessary it’s also not necessary to tape and glue the filter halves together that’s not where the lint is getting into the blue condenser. Also, his pictures of the blue condenser never showed , any significant lint on the condenser there’s no problem with the machine.
He’s also completely confused by technology doesn’t seem to know how to schedule a warranty call understand how deliveries work, when he showing you how the tighten the locknuts on the front feet he’s turning them the wrong way, etc.
Possibly something sharp, like a broken zip pull attached to a bulky item pierced the seal, or hooked through a drain hole in the seal and the seal ripped and twisted up rather than the item ripping.
A common problem with some early washer dryer designs was fastenings like buttons getting hooked in the air vent hole at the front, although that usually ripped the clothing.
Torn door boot on a front load washer
This can happen with any front load washer it’s definitely user air. They didn’t show what item was stuck in the boot probably a pair of jeans with a screwdriver in the pocket, lol.
The unfortunate thing is GE will end up paying for this user error this guy should be a whole lot, nicer with a whole house full of GE appliances. They might get tired of his bullshit pretty quickly Treating the service provider like that is not the way to get good service wait until that refrigerator starts breaking down.
I’m afraid Pete, this video is not worth posting except to show what assholes people can be in this world.
John
Issue is that it's very easy to bend the fins of the heat exchanger - and once they are bend, they impede airflow even worse than some fluff.
While yes any lint build up on the evap isn't optimal, it takes a lot more than you'd think to have any major impact.
Keep in mind most lint is in the front half inch of the heat exchanger, the rest of it will be basically free of any lint.
Today I scrapped a Miele Heat Pump drier from 2011, I bought it second hand for $100 and when it arrived, there were no secondary filters and the front of the evaporator was choked with fluff and lint. I cleaned it out but it never managed to dry a load, it would get warm but never hot, it was either worn out from age or abuse.
I stripped it down for parts as everything other than the sealed system is compatible with the 4 others that I have, what amazed me, is how clean the evaporator and condenser were, considering that the front of the evaporator was originally stuffed full of fluff. For those speculating about the fluff forcing itself all the way through, this is what a 13yo abused dryer looks like.
I had only ever cleaned the front, the rest of the unit is as freshly unwrapped.
The evaporator is at the front, the condenser at the back and there is a secondary condenser in front of the compressor, this is used to dump heat into the room to reduce the temp in the airflow and to help improve the condensation of moisture.
Best of all, I dissaessmbled the entire thing, with just the refrigeration system left on the base, all with a single Torx Screwdriver. No other tools needed
