moonshiner180
Active member
Hello everyone, I recently acquired this GE washer for free, knowing it had some sort of leak issue when filling. The lady said she had someone look at it, and he said if you manually started the wash it would not overflow and leak. From my initial test runs what I have concluded is that it fills up to a certain point and runs just fine, but it leaks water from the bottom of the tub pretty badly. If I run a cycle with hot water after making sure the unit is perfectly level, it does not leak nearly as much and makes it pretty much to the Rinse cycle before leaking everywhere. What I'm guessing is that the tub seal is shot, and that the hot water softens/expands it and then the only warm rinse cycle + run time cools it enough for the problem to recur. Does this sound right and sound like I've pinpointed the issue? I already ordered a tub seal and I'm hoping I'm on the right track.
