"Gray Ghost" Maytag wringer washer - finally!
Decals
Thanks for the info Jim - and yes, I've already been in touch with Kevin the "decal guy". Will be ordering in the weeks to come.
For those interested, I'm posting Vids 7 and 8 showing a load washing and rinsing.
Hi Brad
so far so good with your 30, Good Job!
Im curious about the tub, from the video's it looks like the tub is about the same size as the model E. ??
Bigger, smaller, or the same, would you say?
I think
The E, is supposed to hold 17 gallons The J and the N 16 or 15?
Someone help out here, cant remember!
Just curious as to what the model 30 holds? Looks close to me!
Model 30 tub capacity
From what I can tell, the "gray ghost" model 30's tub capacity is the same as the E2, so that would make it about 18 gallons.
On another note, does anybody know the reason why Maytag went from the tall center post design (as in the Model 30) to the low post in post-war models (as in the E2, J2, N2)?
Hi Brad,
I was told that the center post was changed from long to short spline type when the new white models were made. I know that change happened prewar but don't remember when. There had to be a reason but I don't know it. I will have to ask the Amish about this. I have pics of all Maytag wringers ever made but unfortunately they don't always have money shots of the tub/agitators. I am thinking that possibly the first models that were white may have had the old style post in them. This is a good question !!
Jim
That is a good question and I would venture to guess it had to do with new engineering and serviceability; the "modern" wringer is much easier to service as compared to the older models. Removing the center post on the older machines can be a daunting task; the tub removal alone is difficult and to get it realigned is hard, also. Tub removal on the E, J and N is relatively simple once you get the bolts out at the bottom and you then have clear access to transmission/center post. Removal of the center plate can be done without removal of the transmission.
Question on capacity? Models E and J both held 18 gallons of water while the N held 16. The model 30, etc. had a smaller capacity than the N; about 12 gallons. When originally advertised, the E and J were said to have "50% more capacity" than their predecessors.
Surprisingly ... the first automatics (AMP models) also held about 12 gallons of water; pretty small by today's standards! When Maytag stopped making the AMP design, the tub capacity on their automatics went up to 16 gallons and stayed there until the new series of machines in 1966.
The AMP's were to wash as well as a Model E and the instructions indicated that a homemaker should wash more often than once a week because of the size and automatic ability.
The Maytag Center Post
was shortened due to the "superior Maytag design and engineering". That's what I remember the guy that installed my Mother's automatic back in 1965. Now, I was only 10 at the time so I might be off somewhat. But I remember him pointing out the tall shaft on the old Kenmore we were replacing. He said that most washers had the taller agitator post above the water line as an added precaution against allowing water to seep into the transmission by way of the agitator shaft. But with the Maytag designed water seal that wasn't an issue. He may have just been B.S.ing her but I also remember that was the guy that told her to be sure to Vaseline the agitator shaft once a month to keep it easy to remove. That turned out to be my job and a month never went by that I didn't pull, clean and re-Vaseline that agitator shaft. And boy did I learn that hard way here recently that he was right about that!!
Pics of the paint job in progress - Photo 1
Here are four shots taken today after painting the two front legs ... I decided, at least for the time being, not to detach the legs for painting. In an apartment, I have such limited working space, I think this is the easier method for now.
However, not sure how I'll get the tub re-painted with wonderful results without removing it entirely. Will cross that bridge later!
BTW - thanks to those who recommended "Mother's Mag & Aluminum Polish" - it really works wonders! Just look at the shine on the cap of the gyratator and the crown of the tub!
Pics of the paint job in progress - Photo 3
Photo # 3 Note: the pulley/belt shroud was initially painted with Tremclad "RV White" rust paint, as it was the only stuff I had around at the time and I wanted to see the effect. It matched the beige lower roller in the wringer, which is an interesting look. However, I'll probably paint it green later.
The bakelite knob for the gear shift is in transit - hope it comes soon!
That really looks AMAZING, Brad! That on/off plate is beautiful! Magnificent job on the crown!! Mother's polish is the best.
You would think that there would be something to make that paint adhere to the tub, wouldn't you? I mean ... Maytag had a way of painting those cast parts; why wouldn't a primer work and then the paint?
Painting the tub
Geoff - I'm actually very pleased with the results of that "Valspar" paint from Lowe's. I sprayed it pretty heavily on the lid, so it took about 5 days to really harden, but it's fine now.
Regarding the challenge of painting the tub - I have no concern about the Valspar paint adhering to the aluminum. I just think it would make for a more "even" paint job if the tub was off and painted. But I think I'll just go ahead and do it with the tub attached.
When I've got that done, I'll order the decals from the guy in Ohio.
LOOKS GREAT BRAD!!!
How do you spray paint in an apartment? I couldn't do it in my basement. I did some in the garage then found white paint dust had settled on everything. I did the rest in the back yard. That's the reason I used a roller in the body. Keep up the good work. She's gonna look sweeeeeet!!
Hello Brad
This eighth video was so satisfying, seeing a 79 year old struttin' his stuff like a teenager, hearing you admit how well it removes stains, and watching the colorful load in clear water turn over so rhythmically. How quiet, a hush! The stroke looks just a bit slower than that of the offspring--Yes? The new pix are dazzling. Love the ON OFF and the stick shift. Never really gave Gray Ghosts a second look, nor appreciated them till now. So thanks.
This was my
first view of vid 8. I do believe maybe that mickeyd may be correct in thinking the gyratation may be a bit slower than the newbies. It actually has a great roll over to it. The green paint job is awesome Brad. I know that I am not the only one who is envious of you :-). I also live in an apartment and can't paint. I can't wait to see her all done and labeled adorning your kitchen. Keep up the good work !!
Jim
Correction on Gallons Held ...
Hi again, Brad ... Can't wait to see that tub painted; I'm sure it will look incredible!
I was going through some data on earlier machines last night and found that the Model 30 held 17 gallons of water up to the knurled line on the agitator and 22 gallons if filled up to the crown (not sure why they included that measurement but what the hey!).
So ... they made the Model E wider and added a gallon more in water capacity. I guess the wideness gave the extra clothes capacity. So now I wonder about the water capacity in the AMP models; it HAD to be more than 12 gallons ... probably more like 15 or so.
Fun, fun stuff!! Enjoy and I can't believe you're able to paint in your apartment, either!! :-)
Tub capacity
Hi Geoff ... thanks for that bit of info. You beat me to the punch as I was going to post a note today after doing a couple of loads in the old beauty. I emptied the tub with three-and-a-half 5-gallon buckets, so I was thinking it must be around 17 gallons as well.
As far as the painting in the apartment goes - fortunately I have a corner unit and get a good cross-draft. Otherwise, I don't think I'd be able to do it.
I've included a pic taken today - the underside of the lid has polished up beautifully with some elbow grease, sandpaper, and finally Mother's Mag Polish. The inside of the tub is more of a challenge, but it's coming along slowly. I'm using both 100 grit sandpaper and after a wash, I scrub it with SOS pads.
Maytag wringers
Hi Bradross, Your washer looks amazing and I have enjoyed your videos. I used valspar paint on my model 90 from 1927 and it has really held up great over the years.
Nice job Brad
I really like that green, never knew they had that. I'd always seen flat gray around here. Can't wait to see the tub painted. I think everyone should have a wringer in the collection, my Easy was lying on its side in a barn for 30 years. It took me two years of polishing to get the copper back up to a shine but it looks great now.
I cheated and used white vinyl contact paper on the rollers but after 30 years it still looks good and works well.
enjoy!
Great resto & videos!  I wish I had the time to redo one of mine.  Speaking of that......[COLOR=#ff0000; font-size: large]If anyone is traveling to central PA and would like to purchase a project grey ghost let me know.  I have probably 25-30 in my warehouse that I will never get to.  I need to move them out CHEAP![/COLOR]
Parts from your warehouse Todd?
Wow! 25-30 in your warehouse! Maybe you'd consider parting with a few parts?
I need the bushing that goes on the non-drive end of the bottom roller. It appears to be made of pot metal and mine broke, although I've repaired it somewhat with epoxy.
My list goes on ...
- bakelite knob for the on/off lever ... I received a replica that I ordered from an eBay seller specializing in old vehicles (Model A Ford had the same knob), but the threaded end won't fit.
- gasket for the drain pipe (the "elbow" that joins to the rubber drain hose at the bottom of the tub).
- castors?
Let me know! Thanks Todd.
Brad, let me see what's laying around up there.  I'm going to an auction tomorrow, but I am putting in more OT on Sunday so I'll see what could be parted out.
Update - Video # 9 now released on YouTube
Hey there, everybody...did some more painting today, so all I've got left to do is the tub,wringer housing, and bottom portion of the wringer differential (the bulging part mid-way on the rear left leg, if that's what it is in fact called.)
I was excited to get the replacement replica knob for the gear shift. Not the exact replica, as it should be "mushroom" shaped, but this will do for now. Already spent $15.00 on it through an eBay seller. Maybe I'll find the real McCoy later.
Posted video # 9 on YouTube.
Hay Brad,
A price can't be placed on this beautiful gal. You have done a super job restoring her. LOVE the color. Didn't know they made one that color till you informed us. Can't wait to see more vid's. I still can't believe you were able to do all of this work in your apartment. Best !!
Jim
Refurbishing a #624979S
I have been haunting this site for quite a while because I love antiques and like to learn about them. I have been wanting a wringer washer for a very long time, (along with an older stove and refrigerator) I finally joined because I just acquired a machine very similar to Brad Ross', only with the oval maytag label.
Squeeeeee !! So excited. It is a working model that really needs some cleaning and love.
I think mine is also a model #30.
When I did a test wash, the agitator seemed to do the 180 + and the water spashed considerably more than Brad's does in his video.
Me thinks the "torque for center shaft" part (says a printout) (The squarish top part of the brass center) may be too loose? How would I tell, and exactly how to you remove and put back together? I'm afraid of not being able to replace the pin.
One post commented on the top being too rounded, but my agitator sits quite nicely and I think snug enough... again how would I tell?
Also I am having trouble removing the skale from inside the tub and finding new-er rollers. Any suggestions please?
This is the first time I've ever tried to referbish an appliance and I would not like to mess it up with too much blind fumbling. Where would I get a repair manual. I cannot seem to locate one?
I would appreciate any help and suggestions on my bringing this new addition to my family back to shining life.
On a side note: I also received a N2LS from a friend, but for the life of me I cannot get the agitator off and the crank shaft thingy is to stiff to run. Motor is clean and runs beautiously though.
Thanks.
