Just a random tidbit of amusement...
Remember my '81 Coupe deVille v8-6-4? Well, I decided (after changing oil and such, and getting a wild hair) to take it up to Flagstaff this weekend, since that's always a good idea with a 26-year-old car and one that you've never driven any distance, right?
It made it just fine, and performed flawlessly, though that's a funny story in its own right.
Several miles outside of Tucson, it felt like the transmission was mis-shifting. I tried modulating the accelerator, and noticed that when I accelerated, the car didn't. This could not be good.
Before allowing myself to become embroiled in panic, I wisely poked the "Active Cyl" button on the computer, and found--to my shock--that the readout said:
4
My jaw dropped. The car had never given any hint that the modulated displacement worked, but then again, I'd never driven on the freeway before, either.
I pushed a little on the gas.
6
Harder.
8
After several seconds, the computer decided that I was playing, and made its preference clear yet again:
4
I had to call my dad and Roger to relay this most unexpected info. After leaving the "Active Cyl" displaying, I learned how to interact with the computer to make sure I got the power I needed when I wanted it, and after twenty minutes or so (and a couple of oopsie 4-6-8-4-6-8-4-6-8 shifts when the computer got confused), I had it dialed in.
Throughout Phoenix, the car clung viciously to 4, but would offer me 6 if I insisted. The trick was to push the accelerator (a lot) to make sure I had 8 cylinders available if I needed power. In short, you can't drive this car without developing a meaningful relationship with the computer--you'll be terrorized by its behavior until you learn to use the information readout to your advantage. If you drive it like a normal car and ignore the readout, you'll go nuts (and probably get creamed by a semi, too, when you try to pass it in 4-cylinder mode).
That said, I got about 23-26 mpg out of a 4100 lb car, and I feel like I got a free lunch out of the universe :-D
Now, wish me luck that my return trip is without incident as well
4
6
Harder.
8
4
