kb0nes
Any fine flexible abrasive wheel could be used. At the factory it looks like they are using something pretty coarse and inflexible to grind down the welds, this leaves behind the scratches. Using a tiny Dremel wheel will take forever, you'd be better off working it by hand.
The question still remains "is this an actual PROBLEM in using the machine"? I would wager it is an entire non-issue. With use the scratches will quickly smooth out. While it feels bad when you run your fingernails across the grain of the scratches, remember the laundry will largely be moving with the grain not against it. Also the garments will be swimming in the water and lubricated by the detergent, damage to the clothing would be minimal. I would give SQ the benefit of the doubt there and say they aren't shipping machines that can't be safely used.
Still this is quite an imperfection to find in an expensive new appliance, they need to do better! This is a problem that is similar (and somewhat related) to the black crud in the spin baskets. Their reputation is at stake here. While SQ machines are heavy and solidly built, they are a bit crude and rough around the edges. They don't have the fit and finish of an Asian machine.
