Saving energy while doing laundry
Even if we haven’t made any changes to our routine, we’re all using less energy than we once did thanks to the changes in water, heaters machine, design, etc., imposed by the department of energy.
I’ve always tried to be as economical as possible when doing laundry also my work involves advising people how to use machines to best advantage and we’ve always emphasized getting great results while using the minimum amount of power.
Even Dan with his Maytag and very hot water temperature is using less energy because his water heaters are better insulated than they would’ve been if they’ve been made 40 years ago for example.
Wow Eddie I can’t believe $.40 a kilowatt for power if I was paying that kind of money, they would definitely be some changes that front load washer would’ve gone in long ago and I would’ve figured out a way to put a heat pump water heater in, at our age since we have the money to do these things you’re leaving a legacy behind for the next generation helping to fight climate change by investing in these things even if they don’t pay off entirely in our lifetime.
I’m using half the electricity that I used 20 years ago in my house and have not given up any comfort, even on the hottest summer months here I use less than 1500 kW where I used to hit 3000 years ago. Depending on your laundry appliances, there May or may not be easy ways to save energy, modern machines spin the clothes so dry that that minimizes dryer usage. A dryer is still better for the environment than a conventional dryer because of the amount of Carbon produced running a gas dryer, heat pump dryers will eventually win out, but they come at a much greater cost and also repair rate than conventional vented electric or gas dryers. We’re starting to work on heat pump dryers more and they really are clogging themselves up badly and need extensive tear downs and cleanings after as few as five years to keep them working efficiently.
John
