Did you buy the machine thru choice?
Yes. I had a GE Filter Flo washer and matching dryer, but the washer seemed to be showing signs of age. It didn’t extract water very well, and used a lot of it. I noticed new and worrisome sounds. Since my washer and dryer are in the kitchen, I thought it would be a good opportunity to get a FL washer so I could use the large, flat area on top of the washer and dryer as a work surface.
Has it been reliable?
Yes. I have a first generation Kenmore Elite HE3t, purchased in June 2003. It does not have the original water pump, but my understanding is that drain pumps on that line had some problems, and were replaced by a modified pump. I haven’t had any problems with the redesigned pump. I also replaced the belt after 7 years, since I could hear a slight squeaking noise when washing a large load of heavy towels. I didn’t notice any drum slippage, but I thought it wouldn’t hurt to replace it. I was able to replace the belt and pump in less than 15 minutes – and I am NOT a handy person.
What changes or provisions do you make to get great results?
Using HE detergent, and measuring detergent carefully. Also, taking advantage of the different setting and cycles depending on wash load. Towels are washed on a heavy duty cycle, and dress shirts on a gentle cycle. Short wash for lightly soiled clothes, and longer wash cycles and higher temps for heavy soiled and stained items. While these may seem obvious, I ended up using the same cycle for most loads with my old washer.
Would you have one again?
Absolutely! I love my FL washer. There are so many benefits compared to my older agitator washer. My household water usage was reduced by more than a third. I use less detergent, bleach, and fabric softener. I still have the same bottle of shout stain pretreater as I had when I got my washer in 2003. I love being able to just hit the stain treat button, and the washer adjusts the cycle to remove a variety of different stains using just my regular detergent, all in the same cycle. Clothes last much longer, and look new longer. I use less energy drying the clothes since it extracts so much more moisture from the clothing. I like to hang dry my jeans, and even in the winter I can hang them in my cold basement in the evening, and they are dry by the next day.
Rinsing is better. I have sensitive skin, but can use any detergent since it is all rinsed away. I like the stepped final spin process, which alternates between gradually faster spins and fluffing of the load. Items come out of the washer less damp, yet with less wrinkles than with my old TL washer. Unloading is as easy as loading, as the washed load is a loose heap in the drum.
I like that the water heater can be set at a lower temp, and the washer uses the heater to be sure the wash water is the proper temperature. There is no need to purge the water line in the winter or fussing around to get a truly hot wash. The sanitary cycle allows me to kill germs without bleach, and wash at a temperature higher than I ever could with my water heater turned all the way up using my old TL washer. I like having 6 water temperatures to choose from. (Tap cold, 77F, 104F, 122F, 127F, 153F)
I like that the washer adjusts the water level and cycle based on the load. Large and heavy loads like towels get a deeper rinse and a different, longer final spin sequence than small lightly soiled loads. Using the same cycle and settings, a small load will finish more quickly than a large load, which makes sense to me. If a load is unbalanced, it can easily rebalance the load. It can detect when a load is unbalanced during the slow, distribution spin so no banging. It won’t damage itself or shake excessively by trying to spin an unbalanced load at a high speed.
While my washer is approaching its 11th birthday, it is cleaning as well as it did when I got it. I plan on replacing it with a similar model when necessary. I enjoy older, traditional washers, and am glad to be a part of this site where they are appreciated by people to share my fascination with them.
From a practical standpoint, I believe I have already recovered the cost of both the HE washer and matching dryer in savings of water, electricity, gas, additives, and longer lasting and better looking clothing and towels. There is also the entertainment value, and the satisfaction of having a washing machine that continues to produce excellent results.
Joe
[this post was last edited: 4/7/2014-15:14]
