mickeyd
HI Stevey
You'll still get a cold rinse if you set the temps to warm, but if you do it your way and have the wash set to hot and forget, you'll get no water and for a second think the washer is broken and have a panic attack ;'D
Also, and you'll know this better than I will: Isn't it safer to inlet cold thru the hot rather than hot thru the cold, i.e., is the cold not meant to take hot water or are the valves and their components identical ? I don't know, just thought that the cold can't take heat, whereas the hot is made to take anything. Do you know for sure. I bet you do.
You don't need the Y hose; it's cumbersome and redundant, not to mention WAY MORE WORK> ;=> And Cimberlie says that she has only one tap available.
