crevicetool
Now, I had known for a while that the bearing/seal was going out. It was just a matter of time NOT being available to investigate the repair, blah, blah, blah...
So, here is what I THOUGHT had occured.
That bearing had finally gotten to the point where it had caused enough drag that the extra effort caused the motor to overheat and the thermal thingy kicked out. Not the case. The motor is fried. Once it gets heated up, spin action is slowed, and when the thermal protector kicks out, it is preceded by a loud "buzzing" - that of the motor trying to start up but can't.
A new motor has been ordered.
I think when it comes in and is installed, I might do a video of the operation of this machine if you care to see it....
I'll check back in,
Rick
I'll check back in,
Rick
