One of the lines in my sprinkler system is misbehaving. When operated via the timer, the line receives only a partial flow of water. When I go to the valve and operate them manually, they work fine. I've eliminated the timer and related wiring as the possible cause. I changed out the solenoid on the valve itself, and only saw slight improvement. Before installing the new solenoid, I opened the valve to clear out any possible clog from debris in case there's a difference in routing of the water based on whether the valve is operated manually or via the timer, and I got what appeared to be a decent flow.
Is it time to replace the valve itself? I don't know what else could be causing the problem, but we are quickly heading into irrigation season here so I need to get this fixed.
Any suggestions for further analysis would be most welcome.
