High efficiency Californiaquistan shower heads
I picked up a vintage Speakman showerhead, probably from the 50s. The first shower I took after I installed it was like the heavens opened and the universe sang! After decades of restricted flow...this thing is UNBELIEVABLE! I have zero guilt...I take short showers every other day, quit watering my lawn 3 years ago, and I'm otherwise conscious of any water I use in the house. I've attached photos - it weighs several pounds and has an adjustable stream. (I know it needs cleaning - going to do a vinegar soak soon.) Showers are really a pleasure again!
I have a similar Speakman showerhead.The so called water saver heads used to have a plastic insert you could take out.Then they went to where you could not take the restrictor out.---Solution used the workplace drill press to drill it out-now a shower worth taking!
“We are running out of fresh water”
Huh, doesn’t seem to be a shortage of water after getting nearly 30 trillion gallons of water dumped onto California, there’s even more rain on the way towards the end of the week. Definitely know when the ground is soaked from rain since the septic system is getting full and not because it hasn’t been pumped out or because the leach lines are clogged, it’s because the ground can only absorb so much water before it can’t anymore. Had this happen in January of 2017 since it rained quite a bit around that time as well.
