HOOVER A3786 LOGIC WASHER
Next
The drum, same paddles as your Logic, which, in a way, I should've kept for the Logic Premier or any other possible Logic/EcoLogic Washer Dryer acquisitions.
Final Pic
Last one... First pic of it I took, before I purchased it. Aristocrat badge a bit clearer, sorry bout the fuzziness in the previous pics, they were taken on a new camera.
Bosch Logixx 1400 Washer Dryer WFT2800
Soon, I'm going to be acquiring my Uncle's Bosch Logixx 1400 Washer Dryer WFT2800, which I'm looking forward to, I'll try & get a vid or 02 of it running, next time I visit my Uncle.
It'll come in handy to have as a back up in case my Grandma's Hotpoint Ultima 1600 Washer Dryer WD860 floods the kitchen again, or it over heats or the pump gets blocked with leftover dryer fluff.
My Crew
My Crew, minus the Aqualtis, which's my Mum & Dad's Washer Dryer.
From left to right.
01 Hoover Logic Premier 1250 Washer Dryer A8576
02. Servis Sapphire 1300 Washer Dryer 9635
03. Zanussi JetSystem 1600 Washer Dryer WJD1667W
04. Miele Navitronic 1800 AutoWasher W3985WPS
05. Hotpoint Aqualtis 1400 Washer Dryer AQM8D49IV
My crew
A very impressive line up CJ, how lucky are you. If only i had a place like yours to keep machines, it would be full by now. Well which one do you rate more the Servis sapphire or the Hoover logic.
The Crew
Hi Craig,
In honesty, if it were a comparison, between the Logic Premier, Sapphire & Jetsystem, against the Aqualtis, I can tell you for definite, that the three of mine against the Aqualtis'd be higher in performance ratings, than the Aqualtis. (See Post# 574449, Reply# 37, for the pic of the Premier, Sapphire & Jetsystem).
I only compare them 04 together, because they're all Washer Dryers, whereas the Navi, EcoLogic & Ultima 9566're both AutoWashers & Tumble Dryer separates.
With my 03, in the dryer side, only 01-02 attempts to dry, the Aqualtis, between 03-05 attempts. Even Grandma's Ultima WD860 dries better, the only advantages of the Aqualtis, is the 08KG wash load, steam functions & full/standard size 06KG drying load.
I had a problem recently with the Ultima WD860, it flooded the kitchen for the 03rd time in 06 years, I'm on the look out for a Bosch Logixx 1400 Washer Dryer WFT2800, as a backup to the WD860, should anything dire go wrong with it, as it's not likely that my Uncle'll ditch his WFT2800 in the next year or 02.
Which's your favourite out of my garage line up? Excluding the Aqualtis, as that's my Mum & Dad's.
Servis
Without a doubt the Servis sappire. I've only ever come across 1 Servis quartz style machine in 14 years of working in my job, but i couldn't save it because it was in a very bad state of repair. My all time favourite dream machine still yet to be found, but i doubt i will never ever come across one is the very first automatic my parents owned which was a TI Creda rhythm spin square door. That was some washer, the spin & timer noises that machine made were so unlike any other washer. A very unique piece of engineering.
Hi Craig
Yes, it's a great Washer Dryer, the Sapphire, it does alarm me a bit when it makes a scraping noise, which depends on the load in the drum, if I were going to change anything about it, I'd definitely prolong the 1300RPM part of the spin from its 20 seconds like on the old Hotpoints. I'd also change its operational tendencies, e.g. on spin phases, to keep the user/owner of it guessing, other than me.
I'd increase the spin from 1300 to either 1700RPM or 1900RPM, increase H2O levels, incorporate spin phases during the wash & rinses, to boost washing & rinsing performance.
I've added the 03 links below, to give you ideas on my thoughts, to how the oparational & rogramming should've been programmed & I'd change them to.
Spin Wash example
Progressive spin example
RinseSpin example
ToBe...
CJ
Awesome line up. The Servis Sapphire is my fave - never seen one working though!
The Hotpoint 9566 reminds me of my nans later style WM41 which was just a washing machine - but an excellent one!
Is that the one that boschlover1997 - ilovemiele1- is getting?
Thanks
Jacob
P.S Just noticed your not that far from me :)
Sapphire Cycle Operation
Sapphire Cycle Operation - Now
01. Fill with water.
02. Heat H2O to selected programme set temperature interspersed with slow tumbles.
03. Wash laundry load.
04. Pump out wash water & spin at 90RPM (Distribution speed).
05. Fill & Rinse 01.
06. Pump out water/spin at 90RPM, ramp upto 1000RPM for 20 secs. RinseSpin 01
07. Fill & Rinse 02.
08. Pump out water/spin at 90RPM, ramp upto 1000RPM for 20 secs. RinseSpin 02
09. Fill & Rinse 03 (Fabric softener added).
10. Pump out water/spin at 90RPM, ramp to 600RPM, ramp to 1000RPM, ramp to 1300RPM for 20 secs. Spin Dry 1300
11. Slow down from 1300RPM & stop, or commence selected drying time period.
Sapphire Cycle Operation - My change in opperation sequence
02. Heat H2O to 20°C interspersed with tumbles.
03. Wash laundry load at 20°C.
04. Heat H2O to 30°C interspersed with tumbles.
05. Wash laundry load at 30°C.
06. Heat H2O to 40°C interspersed with tumbles.
07. Wash laundry load at 40°C.
08. Heat H2O to 50°C interspersed with tumbles.
09. Wash laundry load at 50°C.
10. Heat H2O to 60°C interspersed with tumbles.
11. Wash laundry load at 60°C.
12. Pump out wash water & ramp upto 1000RPM for 40 secs.
13. Fill & drain cooldown rinse. Rinse 01.
14. Pump out water/spin at 90RPM, ramp upto 1300RPM, progressive ramp to 1300RPM, hold at 1300RPM for 02 mins, progressive ramp to stop, with filling as ramp down. RinseSpin 01
15. Fill & drain cooldown rinse. Rinse 02.
16. Pump out water/spin at 90RPM, ramp upto 1150RPM for 30 secs. RinseSpin 02
17. Fill & Rinse 03 (Interspersed spins to boost rinsing performance). Rinse 03
18. Pump out water/ramp to 1200RPM, progressive ramp to stop, with filling as ramp down. RinseSpin 03
19. Fill & Rinse 04 (Interspersed spins to boost rinsing performance). Rinse 04
20. Pump out water/ramp to 800RPM, progressive ramp to stop, with filling as ramp down. RinseSpin 04
21. Fill & Rinse 05.
22. Pump out water/progressive ramp to 600RPM, to ramp upto 1000RPM, ramp to 1300RPM, hold at 1300RPM for 04 mins, progressive ramp to stop. Spin Dry 1300.
23. Slow down from 1300RPM & stop, or commence selected drying time period.
