Water Pressure
Craig,
When I first got my Logic Premier, I put it onto programme "F" Special Treatments, it filled ok, but when it got to the point of tumbling, it span too fast, roughly 0250RPM, causing the intaken water to be forced out of the drum vent slot at the back of the machine, lucky it was in the garage, not the kitchen, upon it being tested through a full test wash on programme "D" Non Fastcoloureds, it ran fine, no issues what so ever.
Once it returned to Grandma's, we tried testing for ourselves, it blew the main house fuse. We had Coopers (Repair shop we took it to, our local), come back to inspect it, The PCB/Module board had come adrift of the cabinet. Grandma's handyman, Dave, secured the board away from the suspension pillar - the cause of the fuse blowing, it's worked perfectly since, apart from a squeak when drying, maybe a dry bearing? Dave also fashioned a makeshift water connection, to connect it to the garden hose, but I'll be damned if I know where it's buggered off to, after Dad removed the connector, when he plumbed it back in here at home, but since the removal & where ig ot put, other stuff's been moved since then.
The original verdict over the Logic Premier's issue, before the loose board discovery, was, "The garage plumbing's too strong for a machine as old as this". I'm veering to it being the board that caused the over tumbling issue in the 01st place, what do you think?
I was absolutely heartbroken when Dad decided not to repair our EcoLogic 1200 AutoWasher, and there was one in Coopers too, when ours went up the spout, in the end it sat wedged between fridge freezer & sink cupboard unit, before being stripped for useable parts, Grandma got the inner drum, like your Logic's, for growing her Rhubarb in.
If I had a pic of the rear of the Logic Premier, I'd post it, but the auction I bought it from'll've been deleted from Ebay's records by now, but there're plenty of vids of it running, on my YT channel, my username's WD860.
Link to my channel:
http://www.youtube.com/user/WD860?feature=guide
CJ
